I occasionally record in Audacity, and I’ve encountered an issue lately where the recording from the microphone sounds like its in fast forward.
Any recording done on the system sounds strange, but dosn’t after a reboot. This issue usually occurs at random after some hours that the system has been on.
Is there some service that I can restart instead of having to reboot the entire system?
I’m on KDE Manjaro:
System: Host: MidnightStarSign Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.3 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser/root required> UEFI: American Megatrends v: 1407 date: 04/02/2020
CPU: Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 94837
Speed: 3950 MHz min/max: 2200/3950 MHz boost: enabled Core speeds (MHz): 1: 3950 2: 3950
3: 3950 4: 3950 5: 3950 6: 3950 7: 3949 8: 3949 9: 3950 10: 3950 11: 3950 12: 3950
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: ASRock
driver: amdgpu v: kernel bus ID: 0b:00.0
Display: x11 server: X.Org 1.20.9 driver: amdgpu,ati unloaded: modesetting,radeon
resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz 3: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.39.0 5.9.8-2-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.2 direct render: Yes
Audio: Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 0b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 0d:00.4
Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus ID: 7-2:3
Sound Server: ALSA v: k5.9.8-2-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: f000
bus ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 24:4b:fe:5b:08:2a
Drives: Local Storage: total: 4.64 TiB used: 1.89 TiB (40.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T2B0C-00PXH0 size: 931.51 GiB
ID-2: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
ID-3: /dev/sdb vendor: Seagate model: ST380815AS size: 74.51 GiB
ID-4: /dev/sdc vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
ID-5: /dev/sdd vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
ID-6: /dev/sdj type: USB vendor: Toshiba model: TransMemory size: 14.92 GiB
Partition: ID-1: / size: 767.00 GiB used: 581.58 GiB (75.8%) fs: btrfs dev: /dev/dm-0
ID-2: /home size: 767.00 GiB used: 581.58 GiB (75.8%) fs: btrfs dev: /dev/dm-0
Swap: ID-1: swap-1 type: partition size: 64.00 GiB used: 115.0 MiB (0.2%) dev: /dev/dm-1
Sensors: System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 556 Uptime: 11h 17m Memory: 31.33 GiB used: 19.11 GiB (61.0%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1790 Shell: Bash v: 5.0.18 inxi: 3.1.08
