I have an RTX 3070. I tried playing Sekiro Shadows Die Twice, before installing the 470xx drivers, it started up, but didn’t run very well.
That’s when I realised I didn’t have the latest drivers installed, but after installing them, the game wouldn’t start up at all, when launching it would show a black screen for a short period and then crash.
It must be some sort of proton issue since native games run perfectly fine.
I have tried reinstalling Proton and deleting the compatdata folder already, didn’t help.
Hi weingeist & kisun,
i don’t know much about graphics cards, but what is the reason to not use the 470 drivers with a RTX card. Where do you get those kind of information from and another question. I have an old GeForce 750 Ti, should i install anything else than the “video-nvidia” driver. I didn’t install 390 and not the 470 driver, what would you recommend ?
No, he said “I have video-nvidia installed, should I install 470 or 390 driver?” and my answer was “if you already use the newest driver and it works, why would you want to change to an older?”.
I did not search online for specific driver for that card, but mhwd seems to agree with the choice of the latest driver but maybe that is a bug or mhwd has not been informed by nvidia, IDK.
But @Handspuehler you should probably start your own tread instead of using this.
He said he had a nvidia GTX 750 Ti, this card is EOL and is only supported from a legacy driver… the 470 driver should be the right choice.
Now i found something, that makes your posting almost right, but in my case not.
When you browse on the endoflife-site for nvidia you find under GPU Support a link to the legacy driver series. The site is called “Plan for Kepler-series GeForce GPUs for Desktop” and i asked myself if my GeForce GTX 750 Ti would be a Kepler or not, than i clicked on the Link List of Kepler series GeForce Desktop GPUs, which leads to the site with the detailed answer. Many of the 600er Series cards (like the GTX 650 Ti) and many of the 700er Series cards (like the GTX 760 Ti) are mentioned, but not the GTX 750 Ti.
But my recommendation is to listen to mhwd, you will probably be notified somehow when the card slips out of newest driver.
Maybe they will create a new legacy driver for that and other cards.
If not you will probably start noticing bugs when it happens.
Until then, use latest.
It was in Media a few years ago, that nvidia put nvidia Kepler 7xx Cards in EOL… but as @Handspuehler said already, that the big difference is the 750/750 Ti because this card was released later and based on Maxwell Chip… so you both are lucky now… other Keplers can’t use the newest 545 driver.
Check the compatibility of the games with the specific NVIDIA driver version you’ve installed. Sometimes, certain games might have issues with specific driver versions, and forums or community discussions might highlight these compatibility problems.
