How to remove the Notification Part from GNOME 40
Hi All
I want to remove the Notification Part at the top bar from GNOME 40.
How could I do? Thank you.
The phrase ‘help’ in conjuction with any other words is banned - as you asking a question is implicitly including the word help - which when used won’t get you any further - so don’t use the word help.
Gnome is Gnome and there is nothing you can do to change it.
The forum members are not available for answering questions for which answers could have been found using a simple search - web or otherwise.
try searching, you are not the first person with this question and there are some options. Let us know what worked for you.
