Hello,
Is there a way to configure a wireless connection so that it will automatically connect when a wired connection is deactivated and disconnect when the wired is activated again?
TIA
Hello,
TIA
Got to your settings and set the priority.
Now WLAN is prefered over LAN.
Easy.
Seems to work fine. Thanks a lot.
