More detailed than by Task Manager and HTOP?
By those, Firefox, qbittorrent, and Gajim are the principal hoarders.
The second command does the same thing as the first command. It’s only a different syntax.
Unfortunately, Mozilla software has quite a reputation on account of memory leaks. And browser extensions could even play a role in that.
In that case, the post is solved.
Of the many comments providing similar commands, choosing the one giving alternative versions and on the page itself.
I am running several extensions.
If you use those and find firefox still uses memory after closing it, why not kill the lingering processes and reclaim the memory?
If you don’t find an obvious process that is using the memory, then it is a leak deeper in the stack.
I believe that would work too and will try it next time I experience sluggishness.
However if both methods work, flushing the cache would have the advantage of being the same command every time while identifying the process number and killing it would look different each time.
