I decided to increase the size of a partition in my HDD, but in doing so, because it was so big and was moved to the left, it showed that it would take 10 hours to finish (HDD was 931 GiB big but only about 500 GiB full). So, I decided to force stop it, but after that, all my files are gone. I heard that even if the files are gone, I can still recover them because it doesnβt really wipe them out. How can I recover them? Thanks
neofetch
~ Β» neofetch soumi@Hori
ββββββββββββββββββ ββββββββ soumi@Hori
ββββββββββββββββββ ββββββββ ----------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: Aspire A514-53 V1.16
ββββββββ ββββββββ Kernel: 5.15.2-2-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 15 hours, 31 mins
ββββββββ ββββββββ ββββββββ Packages: 1398 (pacman), 11 (flatpak)
ββββββββ ββββββββ ββββββββ Shell: zsh 5.8
ββββββββ ββββββββ ββββββββ Resolution: 1280x720, 1280x720
ββββββββ ββββββββ ββββββββ DE: Plasma 5.23.3
ββββββββ ββββββββ ββββββββ WM: KWin
ββββββββ ββββββββ ββββββββ Theme: Breath2 2021 Light [Plasma], Breeze [GTK2
ββββββββ ββββββββ ββββββββ Icons: [Plasma], breath2 [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: terminator
CPU: Intel i3-1005G1 (4) @ 3.400GHz
GPU: Intel Iris Plus Graphics G1
Memory: 5009MiB / 7626MiB
inxi -Fazy
~ Β» inxi -Fazy soumi@Hori
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=363676ef-6401-4c77-b58f-69e59d05639b rw quiet
resume=UUID=74191adc-235f-4ce2-b1f3-9f9ec427fcac udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: docker wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Aspire A514-53 v: V1.16
Mobo: IL model: Sneezy_IL v: V1.16 serial: <superuser required> UEFI: Insyde
v: 1.16 date: 01/18/2021
ID-1: BAT0 charge: 32.8 Wh (100.0%) condition: 32.8/53.0 Wh (61.8%)
volts: 16.3 min: 15.4 model: PANASONIC KT004 AP19B5L type: Li-ion
serial: <filter> status: Full cycles: 386
Device-1: hid-f4:73:35:09:1d:b5-battery model: Keyboard K380 serial: N/A
charge: N/A status: Discharging
Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A6 cache:
L1: 160 KiB L2: 1024 KiB L3: 4 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 9524
Speed: 3265 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 3265 2: 3271
3: 3354 4: 3125
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.3x7.5")
s-diag: 388mm (15.3")
Monitor-1: eDP-1 res: 1280x720 hz: 60 dpi: 105 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: HDMI-1 res: 1280x720 hz: 60 dpi: 68 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0401
Device-2: C-Media USB PnP Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:9 chip-ID: 0d8c:013a
class-ID: 0300
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-3: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-4: veth2d4f7c5 state: up speed: 10000 Mbps duplex: full mac: <filter>
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 3.0
lmp-v: 5.2 sub-v: 2405 hci-v: 5.2 rev: 2405
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
service-classes: rendering, capturing, object transfer, audio, telephony
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 2.31 TiB used: 427.72 GiB (18.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: G002 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 54.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD10SPZX-22Z10T1 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: GPT
ID-1: / raw-size: 69.85 GiB size: 68.2 GiB (97.64%) used: 21.89 GiB (32.1%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 489 MiB size: 488 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 162.98 GiB size: 160.96 GiB (98.76%)
used: 128.9 GiB (80.1%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-1: swap-1 type: partition size: 14.9 GiB used: 1.24 GiB (8.3%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 85.0 C mobo: N/A
Processes: 298 Uptime: 15h 29m wakeups: 5 Memory: 7.45 GiB
used: 5.06 GiB (67.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1409 pacman: 1398 lib: 383 flatpak: 11 Shell: Zsh
v: 5.8 running-in: terminator inxi: 3.3.09
