How to re-download older kernel 5.16.20-2-MANJARO or other Unsupported?
Hi, need to do some testing, how can re-download linux 5.16.20-2-MANJARO again with its headers?
I’ve removed it in the past to save some space but need it again.
5.16 is EOL and is thus unavailable from the repositories.
If you do need that version, you’ll need to compile it from the source.
I need to install any kernel which is marked as Unsupported in Kernel System Settings /usr/bin/systemsettings msm_kernel, no matter if I can install it as binary or compile it.
Could you tell me how to compile it and get the same result as if were installed with pacman?
