Red192
9 November 2020 20:42
1
More than 40second of loading time and i would like to know if i can do something about it, i’m currently using manjaro 20.1, kernel 5.8.18, KDE plasma 5.20
I’ve a 8 core Intel i7 4770 (3.40GHz) and 16 gb of ram;
systemd-analyze print out this:
Startup finished in 2.131s (kernel) + 23.037s (userspace) = 25.168s
graphical.target reached after 16.524s in userspace
systemmd blame:
11.659s linux-module-cleanup.service
8.986s NetworkManager-wait-online.service
6.803s snapd.service
6.522s lvm2-monitor.service
4.459s dev-sdb1.device
4.093s polkit.service
2.848s avahi-daemon.service
2.844s NetworkManager.service
2.830s systemd-logind.service
1.678s apparmor.service
1.646s ModemManager.service
1.597s systemd-journal-flush.service
979ms tlp.service
962ms org.cups.cupsd.service
947ms ldconfig.service
947ms systemd-sysusers.service
888ms systemd-modules-load.service
616ms systemd-udevd.service
590ms systemd-tmpfiles-setup-dev.service
560ms udisks2.service
516ms systemd-random-seed.service
482ms modprobe@drm.service
408ms upower.service
387ms systemd-journald.service
381ms systemd-udev-trigger.service
359ms wpa_supplicant.service
282ms systemd-journal-catalog-update.service
234ms systemd-tmpfiles-setup.service
232ms user@1000.service
210ms snapd.apparmor.service
196ms systemd-sysctl.service
161ms dev-hugepages.mount
160ms dev-mqueue.mount
160ms sys-kernel-debug.mount
159ms sys-kernel-tracing.mount
159ms kmod-static-nodes.service
156ms dev-disk-by\x2duuid-ebe13367\x2d2677\x2d4aaa\x2dacf7\x2d3e36346c18bc.swap
133ms rtkit-daemon.service
118ms systemd-binfmt.service
88ms systemd-rfkill.service
84ms systemd-user-sessions.service
53ms systemd-tmpfiles-clean.service
37ms systemd-remount-fs.service
31ms systemd-update-utmp.service
10ms systemd-update-done.service
8ms user-runtime-dir@1000.service
2ms tmp.mount
1ms sys-fs-fuse-connections.mount
1ms sys-kernel-config.mount
1ms proc-sys-fs-binfmt_misc.mount
483us snapd.socket
Howdy!
You can disable ModemManager.service by entering in a terminal: sudo systemctl disable ModemManager.service
May I ask for the output of udevadm info --attribute-walk -n /dev/sda1 | grep 'DRIVERS=="[^"]'
, please?
Sweet! Thank you!
May now enter the following in a terminal:
sudo nano /etc/mkinitcpio.conf
Then find the line starting with MODULES=(
and remove everything in between the parentheses, then add ahci sd_mod ext4
in between.
Next, find the line starting with BINARIES=(
and once again, remove everything in between the parentheses. Thus, you can also add fsck fsck.ext4
if you prefer to quickly check the disk at startup.
Lets move on to the line starting with HOOKS=(
, and remove everything, then add base autodetect
After that, move completely to the bottom, and add
COMPRESSION="cat"
Hit ctrl +s then ctrl +x
You may now execute sudo mkinitcpio -P && sudo update-grub
Reboot and voilà!
Red192
9 November 2020 21:26
5
I was genuinely believing that i was about to destroy my installation lol
8.819s NetworkManager-wait-online.service
6.154s snapd.service
4.756s systemd-modules-load.service
4.716s lvm2-monitor.service
3.402s dev-sdb1.device
2.423s avahi-daemon.service
2.421s NetworkManager.service
2.341s systemd-logind.service
1.857s systemd-journal-flush.service
1.528s apparmor.service
1.302s systemd-sysusers.service
1.281s tlp.service
1.259s ldconfig.service
818ms udisks2.service
567ms systemd-journal-catalog-update.service
554ms systemd-remount-fs.service
537ms systemd-udevd.service
530ms systemd-random-seed.service
527ms wpa_supplicant.service
463ms polkit.service
422ms systemd-tmpfiles-setup.service
413ms upower.service
381ms systemd-tmpfiles-setup-dev.service
327ms dev-disk-by\x2duuid-ebe13367\x2d2677\x2d4aaa\x2dacf7\x2d3e36346c18bc.swap
307ms org.cups.cupsd.service
Startup finished in 2.106s (kernel) + 19.802s (userspace) = 21.909s
graphical.target reached after 14.474s in userspace
We at least got rid of 2 and a half seconds !
Red192
9 November 2020 21:27
7
I’ve leaved two hooks in place, now i try to get rid of them
Red192
9 November 2020 21:29
8
Ah no, i did it at the end. Is already pretty good to me. Thanks, pretty good job
Is your PC a laptop, may I ask?
May I also ask if you use snap packages?
Red192
9 November 2020 21:30
10
I don’t use it and i will disable it. My computer is a desktop
May execute sudo systemctl disable tlp snapd
Red192
9 November 2020 21:35
12
Startup finished in 2.107s (kernel) + 18.790s (userspace) = 20.898s
graphical.target reached after 9.185s in userspace
We can still go lower, but things becomes very complicated…
I think this is the best we may achieve!
Have a wonderful day!!
Red192
9 November 2020 21:37
14
Thank you, next check i might consider to buy a couple of ssds after more than 4 years without upgrading my pc
system
Closed
24 November 2020 21:37
15
