Hi I need to do some changes in my distro manjaro with KDE, but I need to know if there’s some sort of “repository” or “system restore point” alike tool in manjaro to save my current state in my distro, before I made some changes that might be harmful and break my OS.
I mean if something goes wrong, restore my distro.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
