How to port to i3-gaps-next-git?
How do I change i3-gaps with i3-gaps-next-git from AUR? I’ve installed the package and nothing happens. I still get the i3-gaps how do I change so that I run i3-gaps-next-git?
You have to read their documentation GitHub - Airblader/i3: i3-gaps – i3 with more features (forked from https://github.com/i3/i3) and change the .config you currently have to adopt the features of it.
I did read the documentation. So basically I want to add border_radius in my config, for that I need to install i3-gaps-rounded or i3-gaps-next-git which has that feature… but I’t seems that I cannot remove Manjaro i3-gaps nor I can merge with that feaure.
sudo pacman -R i3-gaps
checking dependencies…
:: removing i3-gaps breaks dependency ‘i3-wm’ required by i3exit
:: removing i3-gaps breaks dependency ‘i3-gaps’ required by manjaro-i3-settings
