Hi all, on my MatebookD ryzen i no longer can adjust power saving option in KDE control panel.
Options like “stop chargin after a certain percentage” or “start charging once only below %” keeps resetting instantly.
They worked when i did a clean install of manjaro.
Could someone help me? thanks
I wonder if your system needs a battery system reset? The way to do this is to turn off the power saving controller. Shutdown. Charge the laptop to full 100%. Reboot, turn off power control features, use the laptop unplugged until it shuts down by itself due to lack of power. Recharge it to 100%. That will reconfigure the battery controller charging.
(PS: I would not bother with trying to over-think the charge controller system with those options. Just charge to full when needed and let the hardware charge controller do its thing.).
I’ll try to download the latest manjaro iso and enter the live environment to see if it works.
The problem now is i set a value i want, i click apply, type admin password, change page, reload page and the value is resetted to 50% (default was 70!)
It seems i definitively lost this option.
It used to work when i had a dual boot configuration, with the huawei driver installed in windows. (or in some hidden place of the hard disk).
It worked perfectly…
I probably found a solution: according to this guide , the culprit is the huawei-wmi driver reporting incorrect values.
I followed these steps and now it seems working again!
Battery protection
The Huawei WMI driver `v3.3` to expose battery protection thresholds was merged into kernel `5.5` [[2]](https://github.com/aymanbagabas/Huawei-WMI). There is an issue[[3]](https://github.com/nekr0z/matebook-applet/issues/22) where the hardware reports incorrect values for the charge thresholds, preventing battery protection from working. The maintainer of the driver has stated this should be fixed in userspace[[4]](https://github.com/aymanbagabas/Huawei-WMI/issues/36#issuecomment-657127421).
A temporary fix is to write some sane values to the file:
# tee /sys/devices/platform/huawei-wmi/charge_control_thresholds <<< '40 70'
This will enable battery protection (in this case, the device will stop charging at 70%). In order for [matebook-applet](https://aur.archlinux.org/packages/matebook-applet/)<small>AUR</small> to run without superuser rights, add your user to the `huawei-wmi` group since the thresholds are still read-only to non-root.
usermod -a -G huawei-wmi $USER
Alternatively, [huawei-wmi](https://aur.archlinux.org/packages/huawei-wmi/)<small>AUR</small> will set the group write privileges. This will also take care of the thresholds resetting randomly upon reboot by automatically reinstating the battery charge-thresholds. For more information, see [this guide](https://github.com/nekr0z/linux-on-huawei-matebook-13-2019).
