I Have some questions about mirrors.
1.what are the commands for pacman-mirrors
2.how to only use certain protocols or specific mirrors
3.are http mirrors less secure that https mirrors
See…
man pacman-mirrors
See…
man pacman-mirrors
I don’t see why. The packages are all signed and checksummed, and those signatures and checksums are verified upon downloading the packages.
Anyway, if you only want to use https
mirrors, then you can specify that…
sudo pacman-mirrors -P https
Thanks for helping a responding so quick
Also will the parameters be set automatically once I enter the command
Yes, your selection will be stored in /etc/pacman-mirrors.conf
and remembered.
this command will help you easily choose with a GUI the mirros/countries/Https etc…
pacman-mirrors --interactive --default && sudo pacman -Syyu
