Hello, I have 2 different router, both is plugged in to same slot using lan cable. I switch between them.
I’m trying to give these router different name.
In windows, you do this: How to change network names on Windows 10 - gHacks Tech News
Normally, in windows, there will be different network profile for these router. I can easily name them and change their settings independently. Besides changing name, I can also enable Metered connection to only one router.
But in here, both are using the same profile. If I add new profile, I still need to manually switch between them.
I assume linux can also tell the difference between these two router since they will say different speed?
One router says “Connected - 100 Mb/s” while the other says “Connected - 1000Mb/s”
Edit:
these are the inxi --admin --verbosity=7 --filter --no-host --width
output.
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3d035187-d032-4650-946e-a07db114a455 rw quiet splash apparmor=1
security=apparmor resume=UUID=a744f76f-4318-41b8-8117-a8299568048d
udev.log_priority=3
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <filter>
UEFI: American Megatrends v: P4.30 date: 11/25/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: Discharging
RAM: total: 15.55 GiB used: 3.71 GiB (23.9%)
Info: 6-Core model: AMD Ryzen 5 3500 bits: 64 type: MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB bogomips: 43217
Speed: 3542 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3542 2: 2199 3: 2012 4: 2062 5: 2978 6: 2181
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 09:00.0 chip-ID: 10de:1f82
class-ID: 0300
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 09:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: no
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.96 TiB used: 635.84 GiB (21.0%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 3B2QEXM7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: V-Gen model: 01SM21NT256MT
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5A0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000VX008-2E3164
type: HDD rpm: 5900 serial: <filter> rev: CV12 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 23.81 GiB (24.9%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: linux
uuid: 3d035187-d032-4650-946e-a07db114a455
ID-2: /boot/efi raw-size: 1000 MiB size: 996 MiB (99.60%)
used: 25.5 MiB (2.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D4F8-5870
ID-3: /home raw-size: 390.62 GiB size: 383.49 GiB (98.17%)
used: 13.98 GiB (3.6%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: home uuid: 3b3e44b5-a833-4e09-b668-250413d14da3
ID-4: /mnt/cross_apps raw-size: 332.88 GiB size: 332.88 GiB (100.00%)
used: 31.43 GiB (9.4%) fs: ntfs dev: /dev/nvme0n1p8 maj-min: 259:8
label: CrossApps uuid: 424EFD4D4EFD3A6D
ID-5: /mnt/warehouse raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 566.6 GiB (30.4%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: Warehouse uuid: 9C5EDB7B5EDB4CA0
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: a744f76f-4318-41b8-8117-a8299568048d
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 97.14 GiB fs: ntfs label: N/A
uuid: 56B4F6A3B4F684B1
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 516 MiB fs: ntfs label: N/A
uuid: 50642D1A642D03F6
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/sda2 maj-min: 8:2 size: 237.86 GiB fs: ntfs label: N/A
uuid: 369020BA9020828B
ID-6: /dev/sda3 maj-min: 8:3 size: 508 MiB fs: ntfs label: N/A
uuid: CCDC6803DC67E5E4
ID-7: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
Hub-2: 1-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 1-2.1:3 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:0344 class-ID: 0300
Device-2: 3-4:3 info: Wacom Wacom One Pen Display 13 type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip-ID: 056a:03a6 class-ID: 0300 serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 57.2 C mobo: N/A gpu: nvidia temp: 50 C
Processes: 259 Uptime: 1h 33m wakeups: 10 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1585
pacman: 1578 lib: 473 flatpak: 7 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.06
hmm I’m not sure what other information I can provide as it’s not an error but a question on how to do stuff.
What I wanted to do is making so that if I connect different router or internet to my pc through the same LAN port, I can tell, which router I’m connected to. Like have different name or different network profile.
But in here it’s always use the same profile, and same name, same mac address, always A8:A1:59:84:EA:69 (enp8s0)
regardless of which router I’m connected to. So I can’t tell which router I’m connected to without looking at the back of my PC and see which cable is plugged.
