I tried using GPU command in steam settings and whene starting steam.
I had no clue how kernel versions work. Well, switched to 5.15.
I have deleted bf4 directory in compadata probably a million times, every time I change something I delete it.
Same result, I just had to use Proton 5.0-10.
Steam log seems to have some dxvk problems now.
Running Steam on manjarolinux 21.1.4 64-bit
STEAM_RUNTIME is enabled automatically
Steam runtime environment up-to-date!
Steam client's requirements are satisfied
WARNING: Using default/fallback debugger launch
/home/benedikt/.local/share/Steam/ubuntu12_32/steam
[2021-09-28 14:39:55] Startup - updater built Sep 17 2021 04:27:28
Installing breakpad exception handler for appid(steam)/version(1631912732)
[2021-09-28 14:39:55] Loading cached metrics from disk (/home/benedikt/.local/share/Steam/package/steam_client_metrics.bin)
[2021-09-28 14:39:55] Using the following download hosts for Public, Realm steamglobal
[2021-09-28 14:39:55] 1. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-28 14:39:55] 2. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-09-28 14:39:55] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2021-09-28 14:39:55] Verifying installation...
[2021-09-28 14:39:55] Verification complete
Loaded SDL version 2.0.17-6744061
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:8232): Gtk-WARNING **: 14:39:55.457: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
Runtime for steamwebhelper: defaulting to /home/benedikt/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
+ exec /home/benedikt/.local/share/Steam/ubuntu12_64/steam-runtime-heavy.sh --unpack-dir=/home/benedikt/.local/share/Steam/ubuntu12_64 --runtime=steam-runtime-heavy -- ./steamwebhelper -lang=en_US -cachedir=/home/benedikt/.local/share/Steam/config/htmlcache -steampid=8232 -buildid=1631912732 -steamid=0 -cachedir=/home/benedikt/.local/share/Steam/config/htmlcache -steamuniverse=Public -realm=Global -clientui=/home/benedikt/.local/share/Steam/clientui --enable-blink-features=ResizeObserver,Worklet,AudioWorklet --enable-media-stream --enable-smooth-scrolling --password-store=basic --log-file=/home/benedikt/.local/share/Steam/logs/cef_log.txt --disable-quick-menu
CAppInfoCacheReadFromDiskThread took 27 milliseconds to initialize
Proceed to auto login
(steam:8232): GLib-CRITICAL **: 14:39:57.254: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:8232): GLib-CRITICAL **: 14:39:57.254: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
Opted-in Controller Mask for AppId 0: 0
(steam:8232): GLib-CRITICAL **: 14:39:57.304: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:8232): GLib-CRITICAL **: 14:39:57.304: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:8232): GLib-CRITICAL **: 14:39:57.345: g_main_context_push_thread_default: assertion 'acquired_context' failed
(steam:8232): GLib-CRITICAL **: 14:39:57.345: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
(steam:8232): Gtk-WARNING **: 14:39:57.601: gtk_disable_setlocale() must be called before gtk_init()
local (potentially out of sync) copy of roaming config loaded - 380 bytes.
roaming config store loaded successfully - 380 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 7ms
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/benedikt/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 4.69 seconds
BuildCompleteAppOverviewChange: 117
RegisterForAppOverview 1: 11ms
RegisterForAppOverview 2: 11ms
[1238860]Non-Steam Controller Configs Enabled: 1
GameAction [AppID 1238860, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
pressure-vessel-wrap[8638]: E: Could not create copy "./etc/inputrc" from "/media/storage_drive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier/soldier_platform_0.20210906.1/files/./etc/inputrc" into "/media/storage_drive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier/var/tmp-D0JGA1/usr": renameat: Ulazno/izlazna greška
GameAction [AppID 1238860, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 1238860, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 1238860, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 1238860, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask for AppId 1238860: 0
/bin/sh\0-c\0/home/benedikt/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1238860 -- '/media/storage_drive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/benedikt/.local/share/Steam/compatibilitytools.d/Proton-6.16-GE-1'/proton waitforexitandrun 'link2ea://launchgame/1238860?platform=steam&theme=bf4'\0
Game update: AppID 1238860 "", ProcID 8798, IP 0.0.0.0:0
ERROR: ld.so: object '/home/benedikt/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Starting app 1238860
>>> Adding process 8798 for game ID 1238860
GameAction [AppID 1238860, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
ERROR: ld.so: object '/home/benedikt/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
GameAction [AppID 1238860, ActionID 1] : LaunchApp changed task to Completed with ""
pid 8802 != 8799, skipping destruction (fork without exec?)
>>> Adding process 8799 for game ID 1238860
>>> Adding process 8800 for game ID 1238860
pressure-vessel-wrap[8799]: E: Could not create copy "./etc/inputrc" from "/media/storage_drive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier/soldier_platform_0.20210906.1/files/./etc/inputrc" into "/media/storage_drive/SteamLibrary/steamapps/common/SteamLinuxRuntime_soldier/var/tmp-O4ECA1/usr": renameat: Input/output error
Game removed: AppID 1238860 "", ProcID 8798
Uploaded AppInterfaceStats to Steam
Exiting app 1238860
No cached sticky mapping in ActivateActionSet.Installing breakpad exception handler for appid(steam)/version(1631912732)
[2021-09-28 14:43:37] Background update loop checking for update. . .
[2021-09-28 14:43:37] Checking for available updates...
[2021-09-28 14:43:37] Downloading manifest: https://cdn.cloudflare.steamstatic.com/client/steam_client_ubuntu12
[2021-09-28 14:43:37] Download skipped: /client/steam_client_ubuntu12 version 1631912732, installed version 1631912732, existing pending version 0
[2021-09-28 14:43:37] Nothing to do
GameAction [AppID 1238860, ActionID 2] : LaunchApp changed task to DownloadingDepots with ""
GameAction [AppID 1238860, ActionID 2] : LaunchApp changed task to ProcessingInstallScript with ""
Proton: Upgrading prefix from None to 5.0-1 (/media/Ext4_storage_drive/SteamLibrary/steamapps/compatdata/1238860/)
esync: up and running.
GameAction [AppID 1238860, ActionID 2] : LaunchApp changed task to RunningInstallScript with ""
GameAction [AppID 1238860, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 1238860, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 1238860, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 1238860, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/benedikt/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1238860 -- '/media/Ext4_storage_drive/SteamLibrary/steamapps/common/Proton 5.0'/proton waitforexitandrun 'link2ea://launchgame/1238860?platform=steam&theme=bf4'\0
Game update: AppID 1238860 "", ProcID 12451, IP 0.0.0.0:0
>>> Adding process 12451 for game ID 1238860
GameAction [AppID 1238860, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 1238860, ActionID 2] : LaunchApp changed task to Completed with ""
>>> Adding process 12452 for game ID 1238860
>>> Adding process 12457 for game ID 1238860
>>> Adding process 12458 for game ID 1238860
>>> Adding process 12460 for game ID 1238860
>>> Adding process 12463 for game ID 1238860
>>> Adding process 12465 for game ID 1238860
>>> Adding process 12468 for game ID 1238860
>>> Adding process 12483 for game ID 1238860
>>> Adding process 12489 for game ID 1238860
>>> Adding process 12497 for game ID 1238860
>>> Adding process 12502 for game ID 1238860
>>> Adding process 12515 for game ID 1238860
Game update: AppID 1238860 "", ProcID 12458, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 12458): SteamUtils009 / Utils
Setting breakpad minidump AppID = 1238860
RecordSteamInterfaceCreation (PID 12458): SteamUser019 / User
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198238316408 [API loaded no]
RecordSteamInterfaceCreation (PID 12458): SteamFriends015 / Friends
RecordSteamInterfaceCreation (PID 12458): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 12458): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 12458): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 12458): STEAMAPPS_INTERFACE_VERSION008 / Apps
RecordSteamInterfaceCreation (PID 12458): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 12458): STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
RecordSteamInterfaceCreation (PID 12458): STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
RecordSteamInterfaceCreation (PID 12458): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 12458): SteamController006 / Controller
RecordSteamInterfaceCreation (PID 12458): STEAMUGC_INTERFACE_VERSION010 / UGC
RecordSteamInterfaceCreation (PID 12458): STEAMAPPLIST_INTERFACE_VERSION001 / AppList
RecordSteamInterfaceCreation (PID 12458): STEAMMUSIC_INTERFACE_VERSION001 / Music
RecordSteamInterfaceCreation (PID 12458): STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
RecordSteamInterfaceCreation (PID 12458): STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
RecordSteamInterfaceCreation (PID 12458): STEAMINVENTORY_INTERFACE_V002 / Inventory
RecordSteamInterfaceCreation (PID 12458): STEAMVIDEO_INTERFACE_V002 / Video
RecordSteamInterfaceCreation (PID 12458): STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Fossilize INFO: Overriding serialization path: "/media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/fozpipelinesv5/steamapprun_pipeline_cache".
Game update: AppID 1182480 "", ProcID 12525, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 12525): SteamUtils009 / Utils
RecordSteamInterfaceCreation (PID 12525): SteamUser020 / User
RecordSteamInterfaceCreation (PID 12525): SteamController007 / Controller
RecordSteamInterfaceCreation (PID 12525): SteamInput001 / Controller
Starting app 1182480
>>> Adding process 12525 for game ID 1182480
Fossilize INFO: engineVersion 4222976 is too low for pEngineName DXVK. Skipping.
Game removed: AppID 1182480 "", ProcID 12525
Game 1182480 created interface SteamController007 / Controller
Game 1182480 created interface SteamInput001 / Controller
Game 1182480 created interface SteamUser020 /
Game 1182480 created interface SteamUser020 / User
Game 1182480 created interface SteamUtils009 / Utils
Game 1182480 method call count for IClientUtils::RecordSteamInterfaceCreation : 6
Game 1182480 method call count for IClientUtils::GetAppID : 8
Game 1182480 method call count for IClientUser::GetAuthSessionTicket : 1
Game 1182480 method call count for IClientUser::GetSteamID : 1
Game 1182480 method call count for IClientUser::BLoggedOn : 1
Exiting app 1182480
No cached sticky mapping in ActivateActionSet.Fossilize INFO: Overriding serialization path: "/media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/fozpipelinesv5/steamapprun_pipeline_cache".
>>> Adding process 12742 for game ID 1238860
Fossilize INFO: engineVersion 4198400 is too low for pEngineName vkd3d. Skipping.
pid 12461 != 12460, skipping destruction (fork without exec?)
Game removed: AppID 1238860 "", ProcID 12458
Game 1238860 created interface STEAMAPPLIST_INTERFACE_VERSION001 / AppList
Game 1238860 created interface STEAMAPPS_INTERFACE_VERSION008 / Apps
Game 1238860 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
Game 1238860 created interface STEAMHTTP_INTERFACE_VERSION002 / HTTP
Game 1238860 created interface STEAMINVENTORY_INTERFACE_V002 / Inventory
Game 1238860 created interface STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
Game 1238860 created interface STEAMMUSIC_INTERFACE_VERSION001 / Music
Game 1238860 created interface STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game 1238860 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
Game 1238860 created interface STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
Game 1238860 created interface STEAMUGC_INTERFACE_VERSION010 / UGC
Game 1238860 created interface STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
Game 1238860 created interface STEAMVIDEO_INTERFACE_V002 / Video
Game 1238860 created interface SteamController006 / Controller
Game 1238860 created interface SteamFriends015 / Friends
Game 1238860 created interface SteamMatchMaking009 / Matchmaking
Game 1238860 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 1238860 created interface SteamNetworking005 / Networking
Game 1238860 created interface SteamUser019 / User
Game 1238860 created interface SteamUtils009 / Utils
Game 1238860 method call count for IClientUtils::RecordSteamInterfaceCreation : 22
Game 1238860 method call count for IClientUtils::GetSteamUILanguage : 1
Game 1238860 method call count for IClientUtils::GetAppID : 24
Game 1238860 method call count for IClientUser::GetSteamID : 1
Exiting app 1238860
No cached sticky mapping in ActivateActionSet.ExecuteSteamURL: "steam://open/settings"
ExecuteSteamURL: "steam://rungameid/1238860"
GameAction [AppID 1238860, ActionID 3] : LaunchApp changed task to ProcessingInstallScript with ""
GameAction [AppID 1238860, ActionID 3] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 1238860, ActionID 3] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 1238860, ActionID 3] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 1238860, ActionID 3] : LaunchApp continues with user response "CreatingProcess"
Game update: AppID 1238860 "", ProcID 13379, IP 0.0.0.0:0
>>> Adding process 13379 for game ID 1238860
GameAction [AppID 1238860, ActionID 3] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 1238860, ActionID 3] : LaunchApp changed task to Completed with ""
>>> Adding process 13380 for game ID 1238860
>>> Adding process 13381 for game ID 1238860
>>> Adding process 13382 for game ID 1238860
>>> Adding process 13384 for game ID 1238860
>>> Adding process 13387 for game ID 1238860
>>> Adding process 13393 for game ID 1238860
>>> Adding process 13396 for game ID 1238860
>>> Adding process 13412 for game ID 1238860
>>> Adding process 13417 for game ID 1238860
>>> Adding process 13426 for game ID 1238860
>>> Adding process 13431 for game ID 1238860
>>> Adding process 13441 for game ID 1238860
Game update: AppID 1238860 "", ProcID 13382, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 13382): SteamUtils009 / Utils
RecordSteamInterfaceCreation (PID 13382): SteamUser019 / User
RecordSteamInterfaceCreation (PID 13382): SteamFriends015 / Friends
RecordSteamInterfaceCreation (PID 13382): SteamMatchMaking009 / Matchmaking
RecordSteamInterfaceCreation (PID 13382): SteamMatchMakingServers002 / MatchmakingServers
RecordSteamInterfaceCreation (PID 13382): STEAMUSERSTATS_INTERFACE_VERSION011 / UserStats
RecordSteamInterfaceCreation (PID 13382): STEAMAPPS_INTERFACE_VERSION008 / Apps
RecordSteamInterfaceCreation (PID 13382): SteamNetworking005 / Networking
RecordSteamInterfaceCreation (PID 13382): STEAMREMOTESTORAGE_INTERFACE_VERSION014 / RemoteStorage
RecordSteamInterfaceCreation (PID 13382): STEAMSCREENSHOTS_INTERFACE_VERSION003 / Screenshots
RecordSteamInterfaceCreation (PID 13382): STEAMHTTP_INTERFACE_VERSION002 / HTTP
RecordSteamInterfaceCreation (PID 13382): SteamController006 / Controller
RecordSteamInterfaceCreation (PID 13382): STEAMUGC_INTERFACE_VERSION010 / UGC
RecordSteamInterfaceCreation (PID 13382): STEAMAPPLIST_INTERFACE_VERSION001 / AppList
RecordSteamInterfaceCreation (PID 13382): STEAMMUSIC_INTERFACE_VERSION001 / Music
RecordSteamInterfaceCreation (PID 13382): STEAMMUSICREMOTE_INTERFACE_VERSION001 / MusicRemote
RecordSteamInterfaceCreation (PID 13382): STEAMHTMLSURFACE_INTERFACE_VERSION_004 / HTMLSurface
RecordSteamInterfaceCreation (PID 13382): STEAMINVENTORY_INTERFACE_V002 / Inventory
RecordSteamInterfaceCreation (PID 13382): STEAMVIDEO_INTERFACE_V002 / Video
RecordSteamInterfaceCreation (PID 13382): STEAMPARENTALSETTINGS_INTERFACE_VERSION001 / ParentalSettings
Game update: AppID 1182480 "", ProcID 13450, IP 0.0.0.0:0
RecordSteamInterfaceCreation (PID 13450): SteamUtils009 / Utils
RecordSteamInterfaceCreation (PID 13450): SteamUser020 / User
RecordSteamInterfaceCreation (PID 13450): SteamController007 / Controller
RecordSteamInterfaceCreation (PID 13450): SteamInput001 / Controller
>>> Adding process 13450 for game ID 1182480
ExecuteSteamURL: "steam://store"
Game removed: AppID 1182480 "", ProcID 13450
Exiting app 1182480
>>> Adding process 14170 for game ID 1238860
wine: Unhandled page fault on read access to 00000008 at address 01006ED9 (thread 0260), starting debugger...
^CTraceback (most recent call last):
File "/media/Ext4_storage_drive/SteamLibrary/steamapps/common/Proton 5.0/proton", line 709, in <module>
g_session.run()
File "/media/Ext4_storage_drive/SteamLibrary/steamapps/common/Proton 5.0/proton", line 677, in run
self.run_proc([g_proton.wine_bin, "steam"] + sys.argv[2:] + self.cmdlineappend)
File "/media/Ext4_storage_drive/SteamLibrary/steamapps/common/Proton 5.0/proton", line 669, in run_proc
subprocess.call(args, env=local_env, stderr=self.log_file, stdout=self.log_file)
File "/usr/lib/python3.9/subprocess.py", line 351, in call
return p.wait(timeout=timeout)
File "/usr/lib/python3.9/subprocess.py", line 1189, in wait
return self._wait(timeout=timeout)
File "/usr/lib/python3.9/subprocess.py", line 1917, in _wait
(pid, sts) = self._try_wait(0)
File "/usr/lib/python3.9/subprocess.py", line 1875, in _try_wait
(pid, sts) = os.waitpid(self.pid, wait_flags)
KeyboardInterrupt
Game removed: AppID 1238860 "", ProcID 13382
flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_1.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_2.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_3.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_4.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_5.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_6.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_7.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_8.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache_9.parc LOCK_SH failed. errno = 11flock /media/Ext4_storage_drive/SteamLibrary/steamapps/shadercache/1238860/AMDv1/steamapp_shader_cache.parc LOCK_SH failed. errno = 11Exiting app 1238860
