I tried to make manjaro default by typing
“Sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --debug --recheck sudo update-grub”
And i then got "grub-install: error: More than one install device?.
By default, GRUB remembers the last entry booted. What’s the output of:
cat /etc/default/grub | grep GRUB_SAVEDEFAULT
Sounds like you were following some outdated guide.
yaourt
is deprecated and unsecure, don’t use it. Use pamac
or yay
instead.
The mhwd-chroot
binary no longer exists, use manjaro-chroot
instead which is already installed on a live ISO.
You have two commands, not one try this
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --debug --recheck
then
sudo grub-mkconfig -o /boot/grub/grub.cfg
Hi Simon, it installed the grub files…but it still booted to windows by default… so what should i do next?
the output is True
Yes manjaro-chroot worked on live… hey man i am a newbie to linux, do you have a reference to new commands… i am using the outdated one and they seem to be only one i find… and what should i do next with manjaro-chroot…
They linked it in the post for you… click on the link.
Also please quote texts (highlight the text and click on “Quote”) instead of doing multiple comments.
