Hi there,
My built-in screen is 2560x1600, and the external screen is 1920x1080. In the settings, there is no scale that fits correctly for these monitors. For example, 150% scaling is perfect for my laptop display, but it is very zoomed in for the external display, so I cannot really work on that. I would like to have the laptop displayed scaled 150%, but the external display stays at 100%.
I know that there are some topics already about this problem, however, I tried the solutions, and they didn’t work for me. I’ve been stuck on this problem for weeks now:( That is why I thought maybe I needed more personalized answers.
I tried following the article HiDPI in ArchWiki and used xrandr to adjust the scaling, but it made it worse, so I revered the changes.
here is info:
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=e4ad81d4-7731-470f-a969-f7c198f5731a rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82UX v: Lenovo Slim 7 16ARH7
serial: <superuser required> Chassis: type: 10 v: Lenovo Slim 7 16ARH7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
serial: <superuser required> UEFI: LENOVO v: KLCN19WW date: 06/08/2023
ID-1: BAT0 charge: 53.1 Wh (80.0%) condition: 66.4/75.0 Wh (88.5%)
volts: 16.2 min: 15.4 model: LENOVO AP16L5J type: Li-ion serial: <filter>
status: not charging cycles: 109
System RAM: total: 16 GiB note: est. available: 13.34 GiB
used: 3.34 GiB (25.0%)
Info: model: AMD Ryzen 7 6800HS Creator Edition bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1396 high: 1398 min/max: 400/4785 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 1397 3: 1397
4: 1398 5: 1396 6: 1396 7: 1397 8: 1397 9: 1397 10: 1396 11: 1396 12: 1397
13: 1396 14: 1397 15: 1397 16: 1397 bogomips: 102240
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25e2 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7 bus-ID: 05:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 39.0 C
Device-3: IMC Networks Integrated RGB Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:5285
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1600 s-dpi: 96 s-size: 1185x423mm (46.65x16.65")
s-diag: 1258mm (49.54")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: Samsung LF24T35 serial: <filter> built: 2022 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: right model: BOE Display 0x0aff
built: 2022 res: 2560x1600 hz: 165 dpi: 189 gamma: 1.2
size: 344x215mm (13.54x8.46") diag: 406mm (16") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.8-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:1681 memory: 1.95 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Laptop GPU driver: nvidia v: 535.113.01
device-ID: 10de:25e2 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV REMBRANDT) driver: mesa radv
v: 23.1.8-manjaro1.1 device-ID: 1002:1681 surfaces: xcb,xlib
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 05:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852
class-ID: 0280
Device-2: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
driver: hid-generic,usbhid type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-1:2 chip-ID: 0458:6001 class-ID: 0301
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0bda:4853
Local Storage: total: 931.51 GiB used: 152.14 GiB (16.3%)
model: WD BLACK SN850X 1000GB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 620311WD temp: 35.9 C scheme: GPT
ID-1: / raw-size: 587.49 GiB size: 577.2 GiB (98.25%)
used: 152.07 GiB (26.3%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: e4ad81d4-7731-470f-a969-f7c198f5731a
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 70.1 MiB (27.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 9857-678A
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 341.8 GiB fs: ntfs
label: Windows-SSD uuid: B89658099657C712
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
label: WINRE_DRV uuid: D2BC586ABC584B5D
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-1:2 info: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 1.1
Device-2: 3-3:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: IMC Networks Integrated RGB Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:5285 class-ID: fe01 serial: <filter>
Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Processes: 367 Uptime: 16m wakeups: 484 Init: systemd v: 254
Packages: pm: pacman pkgs: 1398 libs: 395 tools: octopi,pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.30
You cannot imagine how grateful I would be if someone could solve this problem:) Thank you
