On my Dolphin 2 a.txt
is after 10 a.txt
, but in ASCII space is before 0~9. Why?
Because 2 is higher than 1.
I mean the ranking is 10 11 12 1 2 3. Is there any way to get it right?
Rename it to 02 a.txt
Really? 2 a.txt
is shown before 10 a.txt
when sorting by name with natural sorting
enabled.
Check your sort settings:
Alphanumeric filenames…
There’s a good reason that we write dates 2021-04-19
And similarly why we’d write filenames as 01 to 99. If you want to insert another file between 01 and 02 you can use 011 etc.
I always use natural
What’s your locale
Mine (when testing this one) was en_DK.UTF8
zh_CN.UTF-8
I am Chinese.
OK maybe my dolphin is slow.
If I use natural, it will put 2 before 10 and Chinese 2(二) after 1(一)(which by alphabetical order, before.)
