Does anyone know how I change the default from deadline to BFQ? BFQ has a lower latency, for desktop it makes no sense to use deadline because to copy files and do something else, the system starts to choke.
You can use udev rules.
Create a file in /etc/udev/rules.d
called 60-ioschedulers.rules
sudo nano /etc/udev/rules.d/60-ioschedulers.rules
The following lines will give you:
- bfq for non-rotatioal disks
- bfq also for rotational disks
- cdrom/dvdrom drives will remain at the default (mq-deadline)
## set scheduler for SSD and eMMC
ACTION=="add|change", KERNEL=="sd[a-z]|mmcblk[0-9]*", ATTR{queue/rotational}=="0", ATTR{queue/scheduler}="bfq"
## set scheduler for rotating disks
ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="1", ATTR{queue/scheduler}="bfq"
write out (ctl+o), then hit enter, then exit (ctl+x).
Reboot, or force new udev rules:
sudo udevadm trigger
As you probably already know, you can check what schedulers are in use with the command:
grep "" /sys/block/*/queue/scheduler
Thanks!
