How to launch GNOME control center from terminal?
I use both GNOME Shell and Qtile (a tiling window manager). I just want to change WiFi networks. When I’m on GNOME Shell, I just launched Settings or App Launcher from app overview. But, how to do it on a tiling window manager? I use rofi (like dmenu). I found out that the control center has the process name gnome-control-center (found on htop). Launching gnome-control-center on terminal prints the message:
Segmentation fault (core dump)
Questions
  • How to launch GNOME control center on tiling window manager?
  • Or, how to change WiFi networks on command line (so that I may not need GNOME control center) ?
Gnome and Manjaro uses by default NetworkManager.
You can use nmtui to edit or activate connections.
If you need more options, you can use nmcli . But it is more complex, and requires arguments. See nmcli --help
Thank you so much! That app brought me back the memories of working with TurboC, etc.
