Hi,
I’m using a laptop that is connected to 2 external monitors.
Whenever I login after booting I need to manually darken the laptop screen. Also, when the system comes out of hibernation or standby mode, the screen isn’t dark anymore and I have to manually dim it again.
Since I barely need the third (laptop) screen, I want it to be dark by default.
Does anyone know a solution for that?
Thanks a lot and have a great week!
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: plank wm: kwin_x11 vt: 1
dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux base: Arch Linux
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:5 chip-ID: 0c45:6723 class-ID: 0e02
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 7040x1440 s-dpi: 96 s-size: 1862x381mm (73.3x15.0")
s-diag: 1901mm (74.8")
Monitor-1: eDP-1 res: 1920x1080 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: DP-1 res: 2560x1440 hz: 60 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-3: DP-3 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
