How to install R environment on Manjaro Linux? I went to the official website but they don’t have any package for arch to install R language. Could anyone please help to install the whole setup of it?
You can install it from command line with:
sudo pacman -S r
If you have an Intel CPU I’d strongly recommend getting r-mkl
. The steps to get a functioning set up are very easy:
pamac install intel-mkl
pamac build r-mkl
Both packages are in the AUR. If you have a helper like yay
you can use that instead of Manjaro’s pamac
If you install r-mkl
there is no need to install r
. If you’re looking for an IDE I’d recommend RStudio:
pamac build rstudio-desktop-bin
As mentioned above, the Arch wiki has lots of info on all this.
EDIT: pamac
commands edited to reflect that some packages are built from AUR.
Shouldn’t those pamac install
commands be pamac build
commands when the packages are from the AUR?
You’re totally right. Your comment also made me check intel-mkl
and found that is now in community
Comment edited. But, just to make one thing clear, pamac install
when used on an AUR package will then ask for pamac build
anyway, right? One just saves one [Y] click.
Thank you brother
Is there any package to install after that?
