How to install QuickHash Gui in Xfce
#1
I did search for QuickHash in package-manager but could not find, so I downloaded the the zip file to my home folder from http://www.quickhash-gui.org/downloads/
2 dependencies were then required, both are in package-manager and are ‘ gdk-pixbuf2’ and ‘ruby-gdk_pixbuf2’
Then unziped the downloaded QuckHash. Opened the new file and ran ‘execute’ QuickHash-linux-x64 v2.6.9.2 (or the 32bit file as required)
Then I made a link using ‘edit applications’ Now this useful app. works fine.
If you want your helpful tips to be editable and maintainable by others, please create or edit a Wiki article instead. Then, a discussion topic with a link to your Wiki article can be created in this Tutorials section. Alternatively, you can transform your post type to “wiki” type when your forum account has reached level 3.
A separate Wiki account is needed in order to create and edit Wiki articles. Please contact @Rob via PM and ask for a Wiki account.
#2
Is this for any DE or only specific ones?
#3
Why is the link you posted broken?
What the hell does this package do?
#4
Check out the User Manual and find out! :slight_smile:
#5
Yep, the link is broken…
#6
If the download link did not work for you try:
http://quickhash-gui.org/ or https://sourceforge.net/projects/quickhash/
#7
QuickHash is an open-source Linux, Windows, and Apple Mac GUI that enables rapid selection & hashing of data such as files (individually or recursively), text, entire folder trees of files, and physical disks. The user can also compare various files either as a pair or entire folders.
It was designed for Linux, but it is also available for Windows and Apple Mac. MD5, SHA1, SHA256, SHA512 hash algorithms are available.
EDIT: apologies for the necroing…
#8
New QuickHash version 2.6.9 now out:
#9
New version is 2.8.0
#10
Thanks Lolix my mistake (trigger happy) should read v 2.8.0
#11
New version just out 2.8.2
#12
Can be installed from the AUR now
yaourt -S quickhash-gui-bin
Debian binary version, the original archive is mirrored to my sourceforge because there isn’t a direct download link
