How to install PlayOnLinux?
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=840b1e7c-fff0-4c33-be01-3e531245c9fb rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop M1603QA_M1603QA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: M1603QA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: M1603QA.307 date: 05/11/2023
  ID-1: BAT0 charge: 17.9 Wh (36.7%) condition: 48.8/50.0 Wh (97.6%)
    volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: discharging cycles: 1
  System RAM: available: 11.1 GiB used: 3.82 GiB (34.4%)
  Info: model: AMD Ryzen 7 5800HS with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000D
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1462 high: 3200 min/max: 1200/4462 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1200 2: 1200
    3: 3200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
    12: 3200 13: 1200 14: 1397 15: 1200 16: 1200 bogomips: 102242
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 45.0 C
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:5463
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: AU Optronics 0x459d built: 2022 res: 1920x1200
    dpi: 142 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: max: 1920x1200 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (renoir LLVM
    15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Realtek vendor: AzureWave driver: rtw89_8852be v: N/A
    modules: rtw_8852be pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
    bus-ID: 01:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.81 type: USB
    rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 13d3:3571
  Local Storage: total: 476.94 GiB used: 17.31 GiB (3.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL4512HBLU-00BTW
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HXC70W1Q temp: 31.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 17.31 GiB (3.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 840b1e7c-fff0-4c33-be01-3e531245c9fb
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: D0D2-A129
  Device-1: 3-2:2 info: IMC Networks Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 13d3:3571 class-ID: e001 serial: <filter>
  Device-2: 3-3:3 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:5463 class-ID: fe01 serial: <filter>
  System Temperatures: cpu: 52.6 C mobo: N/A gpu: amdgpu temp: 45.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 310 Uptime: 2h 33m wakeups: 20217 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1168 libs: 346 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27```
The default program for opening executable files is Kate and I'm unable to install PlayOnLinux.
Not sure why it won’t include the second part, but I am unable to install PlayOnLinux. It says the default program used to open the executable file is Kate.
playonlinux is in the AUR
If you have trouble … do include the error output.
There’s no error output. One program I’ve tried to run is a game that has installed successfully and indicates with the loading icon that it’s doing something but nothing happens. PlayOnLinux just opens up with Kate in some sort of text box. It appears to be opening just fine in some way but with the incorrect program. I’ll be looking through that link that you provided.
I dont understand.
So … playonlinux was installed successfully?
pacman -Qs playonlinux
And you have separately installed some game?
How have you done these things? How are you trying to launch them?
I should have specified that playonlinux was not successfully installed. The executable install file opened with Kate as the default program and showed up as a bunch of text. I installed the game with wine and attempted to launch it by double clicking it.
So maybe we should start over …
Of course no support can or will be given to some random executable ~‘installed’.
Please remove whatever it is you have partially installed and use the link above to understand the AUR and its prerequisites and then build and install playonlinux.
It is probably an install script that you have not marked as executable. But don’t do that. As a beginner, don’t install things manually. Stick to the packet manager.
Have you considered trying Lutris? It’s in the repo and has replaced my need for PlayOnLinux.
Another vote for Lutris as it is so quick and easy to flip switches to get the best game play experience, or to use different runners.
No way would I go PlayOnLinux with Lutris as an alternative.
Even the Proton Glorious Eggroll guy creates special versions of Proton for it.
