According to some posts here on the forum, I should be able to get it running just by doing this:
$ sudo pacman -S manjaro-pipewire
resolving dependencies...
:: pipewire-pulse-1:1.2.7-1 and pulseaudio-17.0-3 are in conflict. Remove pulseaudio? [y/N] y
:: removing pulseaudio breaks dependency 'pulseaudio=17.0-3' required by pulseaudio-bluetooth
But as you can see there is a dependency issue, so I tried to remove that:
$ sudo pacman -R pulseaudio pulseaudio-bluetooth
checking dependencies...
:: removing pulseaudio breaks dependency 'pulse-native-provider' required by gnome-settings-daemon
But now it’s complaining about gnome-settings-daemon
being in the way and I have a feeling that I should probably not be removing that.
But how would I install Pipewire properly then?
