How to install Manjaro on the Asus t100ta (32bit UEFI / 64bit CPU)
Hello everyone,
I know this topic has already been covered here and someone replied later that an update fixed 32bit UEFI installation. In fact, it didn't work on my Asus t100ta so I've had to dig up the information to do it, so here's my "tutorial".
If i'm not posting where I should, or you have any question, tell me so ! I'm pretty new to the linux comunity though, it's just a summary of what worked for me, this hardware and this version.
Have a nice day !
Here is the Github Gist of the tutorial
EDIT : Tested on Manjaro LXQt, Cinnamon, Budgie and Gnome at the moment.
This method is able to install all of them (some have bugs not related to this).
How to setup Manjaro on the Asus t100ta
Based on this tutorial by jbMacAZ on forums.manjaro.org
Made on 26/05/2020 for the Asus t100ta and Manjaro 20.0.1
These instructions should work for any 32bit EFI / 64bit CPU system, but I only tested it on the Asus t100ta, use at your own risk.
I tested the community editions for Budgie and LXQt, but this tutorial should be good for any 64bit Manjaro edition.
My setup
I'm using vanilla Ubuntu 20.04, you will need gparted and unetbootin for this tutorial.
You will also need a 4GB or more USB stick which data will be wiped.
If like me your t100ta dock is broken, you can charge the computer normally until full, then use the charging micro-usb port to have an OTG cable + USB hub to connect the USB stick, a keyboard and a mouse.
Steps
  1. Download a 64bit manjaro iso of your choice from the official website
  2. Download a 32bit manjaro iso from the 32bit manjaro project site
  3. Download bootia32.efi (or build it) from jfwells "linux-asus-t100ta" github
  4. Format the USB stick to have one fat32 partition of 100% size (you can use disks or gparted to do this)
  5. Label the USB key MANJARO (you can use gparted for this)
  6. Burn the 64bit iso to the stick with Unetbootin (this is important because you want to be able to write on the stick)
  7. Copy bootia32.efi to /efi/boot on the stick
  8. Copy the folder /boot/grub/i386-efi from the 32bit iso to /boot/grub on the stick
  9. Edit on the stick /boot/grub/kernels.cfg replace misolabel=anything_that_is_here to misolabel=MANJARO
  10. Edit on the stick /boot/grub/grub.cfg, find the efi_detect function, replace
    for efi in (*,gpt*)/efi/*/*.efi (*,gpt*)/efi/*/*/*.efi (*,gpt*)/*.efi (*,gpt*)/*/*.efi ; do
    with
    for efi in (*,gpt*)/efi/*/*.efi (*,gpt*)/efi/*/*/*.efi (*,gpt*)/*.efi (*,gpt*)/*/*.efi (*,msdos*)/*/*/*.efi ; do
  11. On the t100ta, reboot and mash F2 to go to BIOS/UEFI. Disable secure boot on the "boot" section
  12. Plug in the USB stick, Save and exit, then mash escape to choose a boot option, then choose the USB stick
  13. On the menu that appears, choose "install manjaro", then install regularly and reboot to your fresh insallation !
Fixes
The screen shuts off regularly and the system hibernates (around every 15 seconds)
  1. For Gnome desktop (based on 5bentz "linux-asus-t100ta" github)
    1. Install gnome-tweak-tool
    2. Open gnome-tweaks
    3. Go to the power section
    4. "suspend on lid closed off" => "off"
  2. For Budgie desktop (based on a ubuntu budgie power management thread)
    1. Open /etc/systemd/logind.conf for edition as admin
    2. Remove the starting # on the lines HandleLidSwitchXXXXX
    3. On these lines, change =suspend to =ignore
    Note : You may want to let some of these options to suspend, for example the "docked" one
  3. For other desktops
    • I tested community edition LXQt+openbox edition which worked fine and didn't have this problem.
      However, if you get this problem i think that the For Budgie Desktop section above may be the universal solution to this problem. I'm no expert though, so you may need some tinkering .
This method also works for XFCE, Cinnamon and Garuda, an Arch based distro with some Manjaro roots. (tested on a Asus T100CHI) This should also work for Old Lenovo and Toshiba 2-in-1's with baytrail processors & uefi32 firmware.
Thanks a lot for this! Just tried with a T100TA, live booting Manjaro KDE and it worked beautifully!
At step 8, when you copy the file from the 32-bit ISO make sure you re name it from I386_EFI to i386-efi
otherwise it wont boot.
An issue i ran into and thought someone else might find useful.
THANK YOU!
It worked... I'm floored!
Booting a MacBook 2,1 and installing KDE Plasma 20.0.3 right now.
