I was trying to use binwalk
and I can’t install cramfsswap
. any help here?
I don’t see such a package in Manjaro’s repos or AUR. Why do you believe you can install it? It seems to be a Debian package.
By the way, binwalk-git was last updated 2018-08-13, so I guess the package is outdated. But you never told how you installed it…
one of the package i want to extract with binwalk is requesting for it
What package? Please tell us what you’re doing if you want help. We’re not here to play 20 questions.
DECIMAL HEXADECIMAL DESCRIPTION
12844 0x322C eCos RTOS string reference: "ecos.bin.gz"
13536 0x34E0 LZO compressed data
WARNING: Extractor.execute failed to run external extractor 'cramfsck -x 'cramfs-root' '%e'': [Errno 2] No such file or directory: 'cramfsck', 'cramfsck -x 'cramfs-root' '%e'' might not be installed correctly
WARNING: Extractor.execute failed to run external extractor 'cramfsswap '%e' '%e.swap' && cramfsck -x 'cramfs-root' '%e.swap'': [Errno 2] No such file or directory: 'cramfsswap', 'cramfsswap '%e' '%e.swap' && cramfsck -x 'cramfs-root' '%e.swap'' might not be installed correctly
2720000 0x298100 CramFS filesystem, little endian, size: 348160, version 2,
sorted_dirs, CRC 0x4CECA79A, edition 0, 93 blocks, 23 files
3211526 0x310106 Zlib compressed data, default compression
the image i want to extract is a satellite receiver firmware but im getting this error
Please don’t post screenshots of text. Instead, edit your post, copy and paste the terminal output, highlight it and use the Preformatted text </> button.
so should i move to debian or will there be a solution?
The program is called fsck.cramfs
in Manjaro/Arch. It is part of util-linux
and probably already installed.
This program is not available, you need to get the source and compile it yourself.
great it works now after installing this two packages from source
