I’m new to the forums and to Manjaro. I come from Debian based distros but this is the first time I use an Arch Linux distro based.
I’m trying to install Codelite but I’m not sure how can I do it because it’s not on official repos.
So… Do you know how could I do it? I’ve read something about using the community repo AUR. I’ve never used it before, and I’m trying to do it but I don’t really know how to build. I’ve tried but this is the farther I’ve been…
which: no wx-config-gtk2 in (/home/minux/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin)
CMake Error at CMakeLists.txt:137 (message):
No functional wx_config script was found in your PATH.
Is the wxWidgets development package installed?
-- Configuring incomplete, errors occurred!
See also "/var/tmp/pamac-build-minux/codelite/src/codelite-14.0/_build/CMakeFiles/CMakeOutput.log".
==> ERROR: A failure occurred in build().
Aborting...
I think I’ve installed the dependencies but it doesn’t seem to work…
Given that you’ve succeeded in what you wanted to do, could you please mark the post that answered your query as the solution? It puts a summary of that post into your opening post, so that people can see that the problem was solved, and how.
I’ve tested it just in case. It seems like it also works with the command pamac build codelite-bin. It has only failed to me when trying just codelite. So the other option also worked for me !
