How to install Brother MFC-L2960DW?
Hello,
as it was promoted as “linuxfriendly” i’ve bought a Brother MFC-L2960DW…but now i’m struggling with the installation.
Linux Packages on Vendorhomepage are only RPM or DEB.
So, the official way (via the linux-brprinter-installer-*) is not possible.
My next try was to find it in the AUR - without success.
Then i tried to convert the DEB-Package with debtab, but was also not possible cause of a bug (Error: You must run at least once "debtap -u" with root privileges (preferably recently), before running this script · Issue #127 · helixarch/debtap · GitHub).
At least i wanted to install it with a PPD file, but wasn’t able to find such a file.
So, i’m actually out of ideas…
The easiest way for me would be to install it from the AUR, but how to get it there?
Is there an “official” way to request it?
Some hints/tips would be great
Thanks in advance and best regards
This printer supports MOPRIA or “IPP Everywhere”. This means you don’t need the printer’s driver (and it’s maybe the reason why they aren’t in the AUR).
Try to connect the printer via Wifi. There is also the package ipp-usb in case Wifi shouldn’t be possible.
I suppose you have manjaro-printer which pulls everything needed? For the wifi scan function you will also need sane-airscan.
A restart may be needed, also check if avahi is running after the restart with systemctl status avahi-daemon.service
After that just use the wizard from the control panel, “Add printer” and it will pull what it needs from the net.
works like a charm - thx for this info
no need to connect via Wifi/USB - as printer is attached via LAN cable and gets a “static” IP from the DHCP server I’ve used IPPS
yes, thats the way - with the info from @jofi to use IPP Everywhere
