Update to the latest kernel from the kernel manager. and try again.
installed 5.9.8-2
zgrep -i -e android -e ashmem /proc/config.gz
# Android
CONFIG_ASHMEM=y
# end of Android
# Android
CONFIG_ANDROID=y
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_ANDROID_BINDERFS=y
CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder"
# CONFIG_ANDROID_BINDER_IPC_SELFTEST is not set
# end of Android
it worked after i ran
mkdir /dev/binderfs
mount -t binder binder /dev/binderfs
Thanks alot
I canāt install on manjaro with the anbox-git package. can you help?
In the kernel 5.10.2 Anbox isnāt working. You should either wait until the stable branch gets the kernel update or switch to testing branch.
Iām on linux 5.9
Even in that Anbox isnāt working. As I tested, it worked in 5.10.4
so can I just switch to testing branch,update the kernel and switchback to stable branch?
No, if you switch back to stable branch the kernel will get downgraded to the current one.
when do you think weāll have that kernel in stable branch?
Now 5.11 is under testing, so 5.10ās later version should be available soon. Because of rolling release the update should be as soon as possible.
Iām now on 5.10.7 but itās still not working.
when try to launch it crashed and the error log is
[ 2021-01-23 05:19:42] [daemon.cpp:61@Run] [org.freedesktop.DBus.Error.ServiceUnknown] The name org.anbox was not provided by any .service files
when try to do modprobe -a binder-linux ashem-linux
it gives error report
modprobe: WARNING: Module binder-linux not found in directory /lib/modules/5.10.7-3-MANJARO modprobe: WARNING: Module ashem-linux not found in directory /lib/modules/5.10.7-3-MANJARO
@SameExpert
Instead of this, do this:
It seems that the kernel itself loads ashmem
but not binder
, so mounting binderfs
works for me.
Also donāt forget following these steps.
Follow this if you havenāt yet.
@SameExpert
so I have to perform the mkdir and mount step everytime I boot and now anbox is working
but there is no internet inside anbox
I tried
sudo systemctl start systemd-networkd
but no results
in a post above shows how to add to fstab
Disable systemd and use network manager, how to is posted in the arch wiki link above
whatās fstab? and which post?
I canāt find it
Itās a file located in /etc
folder.
/etc/fstab
automounts for you everytime you boot your PC. Open it, add this line at the end and save it:
binder /dev/binderfs binder nofail 0 0
Thatās because systemd-networkd
should start before anbox-container-manager
, but you have already started anbox-container-manager
. So you should stop anbox container manager:
sudo systemctl stop anbox-container-manager
You should also enable systemd-networkd
and anbox-container-manager
so that you donāt need to start it everytime, by:
sudo systemctl enable systemd-networkd anbox-container-manager
I directly copied/pasted this code
$ nmcli con add type bridge ifname anbox0 -- connection.id anbox-net ipv4.method shared ipv4.addresses 192.168.250.1/24
from archwiki
Did I need to change any parameters?
It should work. Try rebooting you PC.
[Make sure you have done these steps properly]:
This is what I typed after rebooting my PC and anbox launched successfully.
riyango@cosmoblaze ~> sudo systemctl enable systemd-networkd anbox-container-manager
[sudo] password for riyango:
Created symlink /etc/systemd/system/dbus-org.freedesktop.network1.service ā /usr/lib/systemd/system/systemd-networkd.service.
Created symlink /etc/systemd/system/multi-user.target.wants/systemd-networkd.service ā /usr/lib/systemd/system/systemd-networkd.service.
Created symlink /etc/systemd/system/sockets.target.wants/systemd-networkd.socket ā /usr/lib/systemd/system/systemd-networkd.socket.
Created symlink /etc/systemd/system/network-online.target.wants/systemd-networkd-wait-online.service ā /usr/lib/systemd/system/systemd-networkd-wait-online.service.
riyango@cosmoblaze ~> sudo systemctl start systemd-networkd anbox-container-manager
riyango@cosmoblaze ~> anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity`
But there is still no internet
