How to instal folder for VST-plugins audacity
Hi. I’m totally new with Linux and my stupid question is: what is the right way to create folder for vst-plugins at /usr/bin/? for Audacity use
A folder for VST plugins can be created in one of 3 locations
Installing Effect, Generator and Analyzer plug-ins on Linux - Audacity Manual
  • ~/.vst (plug-ins can be added here with standard user permissions)
  • /usr/lib/vst
  • /usr/local/lib/vst
Root permission is not needed to create a folder in user home folder
mkdir ~/.vst
But if you want it where originally requested
sudo mkdir /usr/lib/vst
