Is the line GRUB_DISABLE_OS_PROBER=false
in /etc/default/grub ?
After that can you execute update-grub
as root on console ?
Can you show fdisk -l
on console ?
on console ?
how to do that…
Sorry I don’t know that much about Linux.
I am very new to Linux. That’s why am having a lot of problems
Please help… tell me what I have to do…
BTW when I write fdisk -l it says permission denied…
outpur of last -Fx shutdown reboot | head
reboot system boot 5.15.16-1-MANJAR Mon Jan 31 22:24:33 2022 still running
reboot system boot 5.15.16-1-MANJAR Mon Jan 31 16:49:27 2022 still running
shutdown system down 5.15.16-1-MANJAR Mon Jan 31 16:43:14 2022 - Mon Jan 31 16:49:27 2022 (00:06)
reboot system boot 5.15.16-1-MANJAR Mon Jan 31 12:34:45 2022 - Mon Jan 31 16:43:14 2022 (04:08)
shutdown system down 5.15.16-1-MANJAR Mon Jan 31 12:34:14 2022 - Mon Jan 31 12:34:45 2022 (00:00)
reboot system boot 5.15.16-1-MANJAR Mon Jan 31 09:10:34 2022 - Mon Jan 31 12:34:14 2022 (03:23)
shutdown system down 5.15.16-1-MANJAR Mon Jan 31 09:09:59 2022 - Mon Jan 31 09:10:34 2022 (00:00)
reboot system boot 5.15.16-1-MANJAR Mon Jan 31 08:28:16 2022 - Mon Jan 31 09:09:59 2022 (00:41)
shutdown system down 5.15.16-1-MANJAR Mon Jan 31 08:27:52 2022 - Mon Jan 31 08:28:16 2022 (00:00)
reboot system boot 5.15.16-1-MANJAR Mon Jan 31 08:01:10 2022 - Mon Jan 31 08:27:52 2022 (00:26)
and output of systemd-analyze blame →
8.568s man-db.service
6.692s snapd.service
6.081s udisks2.service
5.702s systemd-fsck@dev-disk-by\x2duuid-a20bf45d\x2d0ab2\x2d45be\x2d85a2\x2dea013ffde4eb.service
5.700s systemd-fsck@dev-disk-by\x2duuid-B1DE\x2dFBFD.service
5.212s polkit.service
3.944s dev-sda1.device
3.070s cups.service
2.643s bluetooth.service
2.642s avahi-daemon.service
2.633s NetworkManager.service
2.594s systemd-logind.service
2.096s upower.service
2.035s ModemManager.service
1.686s apparmor.service
983ms systemd-modules-load.service
966ms ldconfig.service
805ms systemd-sysusers.service
724ms user@1000.service
629ms lvm2-monitor.service
lines 1-20
All commands must be executed as root
or sudo
So:
sudo fdisk -l
, sudo nano -w /etc/default/grub
and then sudo update-grub
or
login as root on console: su
and then the password of root
again:
your disk is slow (to read)
and: there is hybrid sleep
Windows uses that if not specifically told not to do.
It’s also available on Linux/Arch/Manjaro
The RAM is kept powered - and when you switch on the machine, the return is almost instantaneous.
Only when the RAM is not powered anymore (Battery is drained)
will it use the “saved to disk” copy of the same … which will be slower
because it has all to be read from (slow) disk
Tip: When pasting terminal output on Discourse forums, one can either…
Use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
type or paste code here
Use HTML:
<pre><code>
</pre></code>
I’ve done it for you this time.
Because you need sudo. Correct command is
sudo fdisk -l
Also, did you encrypt any partition or whole disk?
Please share as well output of
inxi -Fza
sudo blkid
cat /etc/fstab
Output of ‘sudo fdisk -l’, ‘sudo nano -w /etc/default/grub’ are
3.070s cups.service
lines 1-20
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
Edit: I changed the grub bootloader to 0 because I don’t use anyother operating system
Thanks for your suggestion. BTW I thought that tags might not work there
I also have a swap memory of something 8gb that is recommended. If it is necessary to increase it then also I can I have lot of free spaces. But seriously all of them for just perfomance in boot speed. Actually, Manjaro works very smooth here but the problem is just with boot power. It is kind of slow. I hope you get it.
As boot speed also matters with SSD which differs from a HDD disk. So, you use SSD or HDD? In my case I use HDD. And it takes almost more than a min to boot.
As people say hibernating help a lot in boot speed. So, why not in my case it is same as before.
When I go to KDE partition manager for checking how much files are stored in Swap it says 0bytes.
What is the reason? Is somthing wrong with the installation?
By the way my goal is to learn Linux. I chose Manjaro as the best linux for me as it is #1 in field of programming and developing. And also it run very smoothly in laptop.
I am just writing post just because I can get the solution. And also if someone get the solution ofcourse the people will remember that for a long term of time. So, that is my deal
Edit: I have posted my all the output above please go and find out and please tell me what to do next.
You should not set the grub timeout
to 0s.
your “systemd-analyze blame” indicates you are booting from a HDD. no configuration would give you the speed bump you can get from upgrading to a SDD. i use to run the manjaro installation i use now on my HDD and get the same kinda numbers. then i migrated same installation to SDD and the speed now is nothing short of great. then i did manage to do arch wiki’s recommendations as well. (the improvements from these are very marginal if not negligible). i’m thinking you are relative noobie into linux and would not recommend you meddle with these configurations now till you get accustomed to it well enough. one small mishap you will be back to square one needing massive rollback, or worse complete re-installation.
https://wiki.archlinux.org/title/Improving_performance
https://wiki.archlinux.org/title/Improving_performance/Boot_process
@Jitesh you ask for help but don’t provide the required information. You have been asked several time to show output of
sudo fdisk -l
inxi -Fza
@Wollie I thought I might have given all the outputs.
Ok,
these are the outputs respectively…
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: HGST HTS541010A9
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 036A4F3F-0E1B-4442-9058-10F9779EBC26
Device Start End Sectors Size Type
/dev/sda1 2048 419432447 419430400 200G Linux filesyste
/dev/sda2 419432448 629147647 209715200 100G Linux filesyste
/dev/sda3 629147648 645924863 16777216 8G Linux swap
/dev/sda4 645924864 646971391 1046528 511M BIOS boot
/dev/sda5 646973440 856688639 209715200 100G Microsoft basic
/dev/sda6 856688640 1066403839 209715200 100G Microsoft basic
/dev/sda7 1066403840 1953525134 887121295 423G Microsoft basic
Disk /dev/sdb: 28.88 GiB, 31004295168 bytes, 60555264 sectors
Disk model: x740w
Disklabel type: dos
Disk identifier: 0x7b9073ed
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2048 60547071 60545024 28.9G 7 HPFS/NTFS/exFAT
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
root=UUID=d5c3546d-c26a-437d-b07c-21a2fa07977c rw quiet
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Notebook
v: Type1ProductConfigId serial:
Chassis: type: 10 serial:
Mobo: Hewlett-Packard model: 80C1 v: 96.51
serial: UEFI: Insyde v: F.27
date: 07/05/2018
ID-1: BAT1 charge: 4.0 Wh (100.0%)
condition: 4.0/41.4 Wh (9.6%) volts: 16.7 min: 14.8
model: COMPAL PABAS0241231 type: Li-ion serial:
status: Full
Info: model: Intel Core i3-5010U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 0x3D (61) stepping: 4
microcode: 0x2F
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4
smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1707 high: 2002 min/max: 500/2000
scaling: driver: intel_cpufreq governor: schedutil cores:
1: 914 2: 2002 3: 2000 4: 1914 bogomips: 16804
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2
ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Type: spec_store_bypass mitigation: Speculative Store
Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline,
IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1616
class-ID: 0300
Device-2: Suyin HP Truevision HD type: USB
driver: uvcvideo bus-ID: 2-5:6 chip-ID: 064e:930b
class-ID: 0e02 serial:
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11
driver: loaded: modesetting alternate: fbdev,vesa
resolution:
Message: Unable to show advanced data. Required tool
glxinfo missing.
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp7s0 state: up speed: 100 Mbps duplex: full
mac:
Device-2: Broadcom BCM43142 802.11b/g/n
vendor: Hewlett-Packard driver: bcma-pci-bridge v: N/A
modules: bcma bus-ID: 0d:00.0 chip-ID: 14e4:4365
class-ID: 0280
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB
driver: btusb v: 0.8 bus-ID: 2-4:5 chip-ID: 0a5c:216d
class-ID: fe01 serial:
Report: rfkill ID: hci0 rfk-id: 0 state: up
address: see --recommends
Local Storage: total: 960.39 GiB used: 43.28 GiB (4.5%)
SMART Message: Unable to run smartctl. Root privileges
required.
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi)
model: HTS541010A9E680 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: rev: A7G0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: HP
model: x740w size: 28.88 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: rev: PMAP
scheme: MBR
SMART Message: Unknown USB bridge. Flash
drive/Unsupported enclosure?
ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%)
used: 22.64 GiB (11.6%) fs: ext4 dev: /dev/sda1
maj-min: 8:1
ID-2: /boot/efi raw-size: 511 MiB size: 510 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 100 GiB size: 97.87 GiB (97.87%)
used: 20.64 GiB (21.1%) fs: ext4 dev: /dev/sda2
maj-min: 8:2
Kernel: swappiness: 60 (default)
cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8 GiB
used: 2 MiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 27.8 C pch: 41.5 C mobo: N/A
Processes: 214 Uptime: 13m wakeups: 1 Memory: 3.75 GiB
used: 2.76 GiB (73.5%) Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1244
lib: 334 flatpak: 0 Shell: Zsh v: 5.8 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.12
BTW what is the normal boot speed of an Manjaro on HDD Hard Drive?
if it is something min then please tell if there is something that I can do to boot in just 20seconds something
As there I have been told that windows use hibernation then why that hibernation not occuring with my laptop? Can’t see swap files? It is actually like I have shutdown my pc, same boot speed and everything like a shutdown but written hibernation which actually do shutdown and nothing
What is file indexing service and how to disable it?
