As the title suggests I can’t pair my Steam controller with the graphical user interface it just won’t show up I tried using “bluetoothctl scan le” but that didn’t work neither please help me because i have no idea what I’m doing and I’m pretty stupid
Is your user part of the input
group?
Run the following in the terminal:
groups
It says
“groups
sys network power lp wheel autologin meca”
I am not sure if i am in the input group or not but i see my username there “meca” so i should be in it?
Then you can add yourself:
gpasswd -a meca input
Yooo thanks a lot!! god bless you
You are welcome.
Does this mean it works now?
In either case … I might suggest the AUR package:
sc-controller
It has a friendly configuration GUI, and should handle any extra dependencies and things.
Yes it works now and it recognizes my other devices as well that i didn’t knew existed in my room crazy
and the sc-controller aur package is amazing thank you so much again
