[Testing Update] 2023-04-25 - Kernels, Virtualbox, LxQt 1.3.0, Systemd 253.3, KDE Gear 23.04, Firefox, Pipewire
Hello community,
Another testing branch update with some usual package updates for you.
get a whopping 82% off + 2 months free on your subscription with Surfshark VPN
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
  • As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Previous News
Finding information easier about Manjaro always has been a topic that needed to be solved. With our new search we have put all Manjaro data accessible in one place and divided by sections so it makes it easier to digest: New Manjaro search engine is available | Blog
Notable Package Updates:
  • All our Kernels got updated
    • we pushed some of them to all branches
    • Real-Time kernels 5.15 and 6.0 EOLed. For now 6.2 series is supported
  • Virtualbox is at 7.0.8
  • LxQt got updated to 1.3.0
  • We adopted Systemd 253 series and updated to 253.3
  • Calamares 3.2.62 includes translation updates and all the fixes we did in 3.2.61 rebuilds
  • KDE Gear 23.04.0 introduces some Plasma-Mobile apps to the regular application suite
  • Firefox is at 112.0.1
  • pipewire we updated to 0.3.70 and pushed to all branches
  • More updates to XFCE
  • Usual KDE-git, Python and Haskell updates
  • We continued to do our Spring-Cleaning
Additional Info
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Info about GNOME 43
GNOME 43 is here! :partying_face:
New in Manjaro GNOME:
Lonely leftover orphan packages that have been removed from the Arch / Manjaro repositories:
  • adwaita-maia
  • dynamic-wallpaper-editor
  • firefox-gnome-theme-maia
  • gtkhash-nautilus
    (Not compatible with Nautilus 43)
  • manjaro-dynamic-wallpaper
  • manjaro-gdm-tweak
  • nautilus-terminal
    (Not compatible with Nautilus 43 & EOL)
Our current supported kernels
  • linux419 4.19.281
  • linux54 5.4.241
  • linux510 5.10.178
  • linux515 5.15.108
  • linux61 6.1.25
  • linux62 6.2.12
  • linux63 6.3.0
  • linux62-rt 6.2.0_rt3
Package Changes (Fri Apr 14 03:49:07 CEST 2023)
  • testing community x86_64: 922 new and 939 removed package(s)
  • testing core x86_64: 23 new and 22 removed package(s)
  • testing extra x86_64: 581 new and 576 removed package(s)
  • testing kde-unstable x86_64: 374 new and 374 removed package(s)
  • testing multilib x86_64: 24 new and 28 removed package(s)
A detailed list of all package changes can be found here
0 voters
Known issues and solutions
:arrow_right: 2023-04-25
2023-03-28
Info about recent GRUB changes
[Unstable Update] 2023-02-17 - Plasma 5.27 LTS, GNOME, Python - #51 by philm
Info about recent NVIDIA packaging changes
[Testing Update] 2023-03-25 - Kernels, Firefox, Deepin, GNOME, NVIDIA, Wine - #42 by philm
2023-03-11
Possible kernel fs block code regression in 6.2.3 umounting usb drives
With kernel 6.2.3 when you simply plug in a usb external drive, mount it and umount it, then the journal has a kernel Oops. A bug report, that includes the journal output was submitted at. https://bugzilla.kernel.org/show_bug.cgi?id=217174 Discussion can be found here: Re: Possible kernel fs block code regression in 6.2.3 umounting usb drives — Linux Stable Kernel Updates
kernel 5.15.99+ Black/empty screen during boot with i915 Intel gfx. No ways to do anything
Seems there is a regression introduced with 5.15.99 kernel update: [i915]drm:add_taint_for_CI [i915]] CI tainted:0x9 by intel_gt_init+0xae/0x2d0 [i915] (#8284) · Issues · drm / intel · GitLab. My thoughts here: [Testing Update] 2023-03-11 - Kernels, Mesa 22.3.7, Phosh, LibreOffice 7.4.6 - #31 by philm
2023-02-10
Switch to the base-devel meta package requires manual intervention
2023-02-12 - Robin Candau
On February 2nd, the base-devel package group has been replaced by a meta package of the same name.
If you installed the base-devel package group prior to this date, explicitly re-install it to get the new base-devel package installed on the system:
pacman -Syu base-devel
Arch Linux - News: Switch to the base-devel meta package requires manual intervention
2023-01-17
Very slow shutdown when using KDE Plasma Wayland
The issue is sddm that can not be finished until the default timeout 90 sec.
The solution: Install sddm-git
The known bug reports:
PHP 8.2 update and introduction of legacy branch
2023-01-13 - Pierre Schmitz
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php and php-legacy can be installed at the same time as the latter uses a -legacy suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap extension will no longer be provided as it relies on the c-client library which has been abandoned for many years.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
2023-01-04
Some games like Dota 2 are freezing
The issue is caused by update libx11 1.8.3-4
The solution: Upgrade to libx11 1.8.3-5
VLC crashes when playing a video file
It looks like there has been a regression introduced with the new version of libva (2.17.0), which is used by VLC media player. If you get the following error when executing vlc in a terminal:
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
you may try to change the Output option in Preferences > Video to VDPAU output instead of Automatic (or whatever value it had been set to before).
Downgrading the libva package from 2.17.0-1 to 2.16.0-1 may also work, but it is a more short-term workaround that should not be kept for too long, as sooner or later, the older package won’t be compatible with the other packages. Consider to do the solution above first.
2022-12-22
pacman-mirrors was temporarily renamed to manjaro-mirrors (the changes were reverted)
This was done to avoid confusion with an AUR / WSL package with the same name and avoid possible breakage. It should be a seamless transition.
Rename project (#183) · Issues · Applications / pacman-mirrors · GitLab
2022-12-19
KDE Wayland sometimes hangs with mesa 22.3.1 and AMD GPU
2022-12-16
dbus-x11 demoted to AUR
dbus-x11 was installed out of the box on some flavors of Manjaro as of a year ago, but is no longer needed. If you have it installed, please replace it with dbus using the following:
sudo pacman -Syu dbuswiki post
XFCE becomes unusable if libxfce4ui-nocsd is still installed
So far XFCE Classic project hasn’t updated yet to 4.18 series. We pushed 4.17.0 version of the package, but don’t know if that helps in that situation. It is recommended to install the regular libxfce4ui package to avoid issues and comment on this issue: libxfce4ui 4.18.0 released · Issue #15 · Xfce-Classic/libxfce4ui-nocsd · GitHub
2022-12-04
python-cairo 1.23.0-2 update requires manual intervention
The python-cairo package prior to version 1.23.0-2 was missing the compiled python module. This has been fixed in 1.23.0-2, so the upgrade will need to overwrite the untracked pyc file that was created. If you receive this error
python-cairo: /usr/lib/python3.10/site-packages/cairo/__pycache__/__init__.cpython-310.pyc exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/python3.10/site-packages/cairo/__pycache__/\*
to perform the upgrade.
2022-11-08
Pop Shell issues with Xorg session with Mutter 43.1 (fixed with mutter 43.1-1.0)
Gnome 43 (X11) GTK4 windows failed to render · Issue #1541 · pop-os/shell · GitHub
Window actors call update_stage_views() without allocation after non-interactive resize on X11 (#6054) · Issues · GNOME / gnome-shell · GitLab
2022-10-28
signature from "Manjaro Build Server <build_at_manjaro_dot_org>" is unknown trust
Seems our signing key for our Build Server had the 2022-10-28 as expire date set when generated. This is now fixed for chroot builds and fresh as also current existing installs via manjaro-keyring 20221028-4 Simply update your system to get that package, which got pushed to all our branches.
2022-10-27
Kernel 6.1-rc# might break backlight control on old/weird laptops
2022-10-18
Firefox 106.0 may have issues with screen sharing on GNOME with Wayland
2022-09-23
Nvidia 3060RTX cards may have issues with the 515.76 driver (fixed with 520.56.06)
Removing python2 from the repositories
2022-09-23 - Jelle van der Waa
Python 2 went end of life January 2020. Since then we have been actively cutting down the number of projects depending on python2 in our repositories, and we have finally been able to drop it from our distribution. If you still have python2 installed on your system consider removing it and any python2 package.
If you still require the python2 package you can keep it around, but please be aware that there will be no security updates. If you need a patched package please consult the AUR, or use an unofficial user repository.*
Arch Linux - News: Removing python2 from the repositories
* Note: Unofficial user repositories are not supported
A post was split to a new topic: Error with kernel 5.15 with mkinitcpio
A post was merged into an existing topic: Error with kernel 5.15 with mkinitcpio
systemd 253.3-2 has a regression again… [SOLVED] TPM2 barrier not starting error...when I don't use TPM@ / Kernel & Hardware / Arch Linux Forums
systemctl status systemd-pcrphase.service
shows start condition failed and you get this line in dmesg:
systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/St
ubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
I’ve tried passing --graceful for the service exec for /usr/lib/systemd/system/systemd-pcrmachine.service as per the man pages, but to no avail.
edit: It only does it on kernel 6.1.25… could be hardware specific. I wouldn’t worry too much about it.
Cannot reproduce here:
However, I haven’t rebooted for a day or so. Kernel 6.2, SecureBoot enabled, TPM enabled.
EDIT: all good after reboot, too.
