I by mistake gotten rid of the toolbar on Thunar and how do I get it back?
If I figured this out I’ll post solution.
I’m not quite sure what the “toolbar” is - my language is different and so are the names for these things.
If you lost your menu (File, Edit, View …) then pressing F10 brings it up and you can enable it again
or you can just keep it like that and use F10 whenever you need that menu.
Thanks. I found out F10 but I don’t see the settings for the menu bar.
Thanks I just did CTRL-M.
