Every time I use Esc I lose the focus the actual app. That shouldn’t be that way. So, how I get the normal behavior back?
Hi @anon43691957, and welcome!
I assure you, on my Plasma it works as you mentioned. So I’m thinking the only way was if there is, somehow, a Custom shortcut overriding it.
Check in System settings → Keyboard → Shortcuts:
https://i.imgur.com/3esppfv.png
Hope this helps!
With a default setup you don’t.
It must be something local to your system.
Ok, thanks. There was a shortcut “plasmashell” that had Esc. But I dont remember to add that.
Now it’s normal again.
