Thanks for that hint . . . might be a factor in the anti-social behaviors of those systems.
It took me years of sharing ESPs with OSX and linux to finally get that, there can be more than one ESP on a drive. Sometimes it takes a few tries to get the installer to “understand” that, e.g., sda1 isn’t where you want /boot/efi to be directed . . . . Sharing the esp with OSX would result in all of the linux location UUIDs being erased or changed.
From experience, our friends Deb+Ian can be quite the biatch, in that regard; even when using separate drives. Although there are ways to overcome it while still being amenable to each OS; albeit not as easily when using only a single drive.
There should only be one ESP on a drive. As mentioned, I’ve seen cases where additional vfat (fat32) partitions have been created on which to install additional bootloaders; but more than one fully qualified ESP should not exist on one drive. That’s the theory. I’m sure there are poorly-written tools in the wild that still enable the possibility.
/boot/efi is usually a symbollic link to the ESP, and might expand to something like /boot/efi/EFI/BOOT/ or /boot/efi/EFI/GRUB/; it’s a mount point, not actually the EFI.
I’d never even attempt that; for a start, the underpinning format of a Mac ESP is HFS+ as opposed vfat; unless it’s a H’tosh, ofcourse, which is a topic for other forums. Again, using separate drives is the way to go (wherever possible).
It is a grey zone, entirely dependent on what the UEFI Manufacturer decided. Works in my case, may not work for everybody. Won’t recommend such experiments for everybody.
Are you certain? A qualified ESP should always have a hex code of ef00; if it doesn’t, then it’s a standard vfat partition. I’m uncertain how to verify that post-creation; but that would be handy to have.
The code is assigned when the partition is created and formatted, though I recall some [older] partitioning tools disguising this fact, and referring to the partition simply as vfat. Gdisk, is my tool of choice; with it, the appropriate code is specified manually for every partition created.
As listed above - p1 and p7 are both ESPs. The “problem” is it is not strictly in the specification, so maybe other UEFI firmwares will not tolerate such a thing. Mine does.
“It might seem like the ESP is unique to a disk and there can be only one ESP for a disk based on the way the OS treats the ESP. Unlike MBR, on GPT, the ESP doesn’t have to be at the beginning of the disk and there can be many ESPs for a disks. This will allow you have multiple boot environments with different configurations for a single disk. You can have Debian EFI and Windows EFI on the same disk, isolated from each other, without having to chainload boot executables. You can even have another ESP with some other boot environment like Ventoy on the same disk, allowing you too boot linux live environments without an external storage ( I will write another article on this).”
I know how to disable os-prober on a given OS, but I have no idea how to remove grub from an OS. How?
Hello, everybody!
Thank you all for your valuable info and support!
I’m a novice. Complete novice in Linux. I study it and the possibility to move from Windows to Linux. My main field of interest is graphic design and photo/images processing.
My PC which is powered by Linux is more than 10 years old. It has UEFI BIOS, Intel CPU, Radeon HD7750 Card.
I have 3 hard disk drives installed: SSD SATA drive (on which all three linuxes are installed, each on its own partition), two HDD SATA drives. And yes, 3 linuxes - 3 individual ESP partitions on the same SSD.
If I enter UEFI while booting - I can see no info about Linuxes installed. The boot menu shows the old Windows bootloader (there is no Windows on the PC anymore), hard disks, DVD ROM, USB. No Linuxes in the list of boot priority.
What I can do is to reinstall all the linuxes in the following way:
(a) I will install Manjaro on SSD (as a main OS), (b) I install Linux-B on HDD-2, and (3) I install Linux-C on HDD-3.
In this particular scheme of installation, I just only have to set SSD (with Manjaro installed on it) as the first disk to boot in UEFI, and then I can switched OFF os-probers on Linux-B and Linux-C.
Just for information. I booted Manjaro from Fedora, MX-Linux, OpenSUSE Tumbleweed, Debian 12.1 and 12.2 GRUB menus with no problem. And I booted all the above-mentioned Linuxes from Manjaro GRUB menu. All this I did in 2023.
For a good deal of reasons Manjaro was is and will be my main OS. I just want one or two more OS just for experimenting and and studying. Linux gives such an opportunity so why to neglect it?
Probably the same way that you would disable os-prober?? But, Manjaro has a nice GUI app for handling software install and removal . . . if an app is already installed next to it will be a red trash can icon . . . click on it and then I believe it asks to “apply??” and you click yes and it is removed. Since you want grub in Manjaro, then you want to remove it from the other two systems, openSUSE uses YaSt to do that GUI service, I don’t know anything about MX-linux . . . they probably have a “software” package service. In ubuntu we used to add “synaptic package manager” and synaptic would show packages that are installed and you can remove them that way.
It can of course be done via command line, based upon the system you choose.
You shouldn’t have to reinstall your three systems, if grub is booting them, then they “exist” . . . you just want to have Manjaro as the “master controller of grub” . . . it seems like grub is already installed in Manjaro . . . just clip it in the other two.
As far as multi-booting, yes, the joy of linux is the infinite number of OSs to play with; three is very “reasonable,” . . . . : - )
OK. Maybe I used barbaric means, but I removed grub from Debian and Tumbleweed by using
sudo apt-get purge grub-common and sudo zypper remove grub2. Manjaro is now the king of the hill (at least IMHO). Let’s see the consequences. )
