How to find manjaro tools?
I’m not sure how it is really named. Somehow I lost the UI utility to install kernel, language packages from manjaro. Looking for manjaro in menu gives me no apps. When I try to find some manjaro packages, there are so many and I can’t recognize the right one.
Which package should I install?
EDIT: Found it: manjaro-settings-manager
Hello :waving_hand: .
On the Gnome side it is called “Manjaro Settings Manager“ with three vertical switches icon. I think that could be this one that you are looking for :vulcan_salute: .
