I tried unmuting several controls in alsamixer. Also tried “aplay -D sysdefault:CARD=ODROIDN2 ”, no sound output. The amplifier and speakers are ok, they work when connected to my other PC
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Alternatively, paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB, causing it to render the same way as descrribed above.
Thereby improving legibility and making it much easier for those trying to be of assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
As I am not allowed to post links or screenshots, I am posting the contents of a post originally in Armbian forums.
# Reset and re-initiate ALSA mixer states
rm /var/lib/alsa/asound.state
alsactl init
# Enable 3.5mm output
amixer -c 0 set 'TOACODEC OUT EN' 'on'
# Use I2S B as source for 3.5mm output, I2C A is somehow not usable
amixer -c 0 set 'TOACODEC SRC' 'I2S B'
# Use ALSA device 0 as input for I2S B
amixer -c 0 set 'TDMOUT_B SRC SEL' 'IN 0'
# Enable I2S B (SRC 2) on device 0 (_A)
amixer -c 0 set 'FRDDR_A SRC 2 EN' 'on'
# Set output channels for device 0 (_A)
amixer -c 0 set 'FRDDR_A SINK 1 SEL' 'OUT 0'
amixer -c 0 set 'FRDDR_A SINK 2 SEL' 'OUT 1'
amixer -c 0 set 'FRDDR_A SINK 3 SEL' 'OUT 2'
# Set master volume to 85%
amixer -c 0 set 'ACODEC' '85%'
Got the link with the search phrase “3.5mm Audio Jack not working”
Beware there is a nasty pop when the media starts playback
