How to Enable Touchpad Toggle with Indicator Light on HP Laptop in Manjaro?
Hello everyone,
I recently switched from Windows to Manjaro on my HP laptop, and I used to have a feature where I could disable the touchpad with a three-finger tap. When the touchpad was disabled, a small indicator light on the top-left corner of the touchpad would turn on, and tapping three times again would re-enable it, turning the light off.
Is there a way to replicate this functionality on Manjaro, specifically with the three-finger tap to toggle the touchpad and, ideally, getting the indicator light to work as well?
xinput list gives me this:
xinput list         ✔
WARNING: running xinput against an Xwayland server. See the xinput man page for details.
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ xwayland-pointer:10                       id=6    [slave  pointer  (2)]
⎜   ↳ xwayland-relative-pointer:10              id=7    [slave  pointer  (2)]
⎜   ↳ xwayland-pointer-gestures:10              id=8    [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ xwayland-keyboard:10                      id=9    [slave  keyboard (3)]
