A recent update broke an app that uses TLS 1.0. How can I enable it back? Fedora has something like this:
update-crypto-policies --set LEGACY
How can I do this on Manjaro?
TLS 1 is pretty outdated and should not be used.
Maybe your app needs a new update/version.
If your app is installed from the AUR, did you try to rebuild it?
It’s a Java app that auto updates on every run, it uses TLS 1.0 and I can’t do anything about it.
I found a solution though, the fact that Manjaro keeps Java config in /etc confused me a little bit.
I followed these steps and it’s all good now. I hope the app will get updated soon and this workaround won’t be needed anymore.
