As the title explains says, i want to enable that option in my xfce4 session. In the Mouse and Touchpad, the option isn’t there. I have cinnamon and plasma installed and both have it installed in their menus, do it need to edit any specific configuration file? Any help is appreciated
inxi -Fazy:
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=59c11c55-cdfa-4660-b66a-21721236e744 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Dell product: Vostro 3590 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0MD5GD v: A00 serial: <filter> UEFI: Dell v: 1.12.0
date: 04/07/2021
ID-1: BAT0 charge: 31.8 Wh (92.7%) condition: 34.3/42.0 Wh (81.7%)
volts: 12.9 min: 11.4 model: SMP DELL VM73297 type: Li-poly serial: <filter>
status: Charging
Info: Dual Core model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 4 MiB
bogomips: 20810
Speed: 800 MHz min/max: 400/4100 MHz Core speeds (MHz): 1: 800 2: 2307
3: 1423 4: 1008
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0bda:5520 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 02:00.0 chip-ID: 168c:0042
class-ID: 0280
IF-ID-1: pan1 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
chip-ID: 0cf3:e009 class-ID: e001
Hardware-1: Intel Device driver: ahci v: 3.0 port: 4060 bus-ID: 00:17.0
chip-ID: 8086:02d7 rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 170.48 GiB (18.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 0D scheme: GPT
ID-1: / raw-size: 341.8 GiB size: 335.36 GiB (98.12%) used: 27.66 GiB (8.2%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 293.33 GiB size: 287.66 GiB (98.07%)
used: 142.83 GiB (49.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 220 Uptime: 4m wakeups: 1 Memory: 3.69 GiB used: 1.31 GiB (35.5%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1485
pacman: 1480 lib: 395 flatpak: 5 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.08
