hello everyone,
Please help me I am a beginner
I just switched to zsh and want to disable the powerline it is making shell loading slower. and also want to change the prompt.
I have added these line to .zshrc other settings are default.
# Use powerline
USE_POWERLINE="true"
# Source manjaro-zsh-configuration
if [[ -e /usr/share/zsh/manjaro-zsh-config ]]; then
source /usr/share/zsh/manjaro-zsh-config
fi
# Use manjaro zsh prompt
if [[ -e /usr/share/zsh/manjaro-zsh-prompt ]]; then
source /usr/share/zsh/manjaro-zsh-prompt
fi
export EDITOR=nvim
alias nv='nvim'
#coloured aliases
alias ls='ls --color=auto'
alias grep='grep --colour=auto'
alias egrep='egrep --colour=auto'
alias fgrep='fgrep --colour=auto'
# vi mode
bindkey -v
export KEYTIMEOUT=1
# Enable searching through history
#bindkey '^R' history-incremental-pattern-search-backward
# Edit line in vim buffer ctrl-v
autoload edit-command-line; zle -N edit-command-line
bindkey '^v' edit-command-line
# Enter vim buffer from normal mode
autoload -U edit-command-line && zle -N edit-command-line && bindkey -M vicmd "^v" edit-command-line
# Use vim keys in tab complete menu:
#bindkey -M menuselect 'h' vi-backward-char
#bindkey -M menuselect 'j' vi-down-line-or-history
#bindkey -M menuselect 'k' vi-up-line-or-history
#bindkey -M menuselect 'l' vi-forward-char
#bindkey -M menuselect 'left' vi-backward-char
#bindkey -M menuselect 'down' vi-down-line-or-history
#bindkey -M menuselect 'up' vi-up-line-or-history
#bindkey -M menuselect 'right' vi-forward-char
# Fix backspace bug when switching modes
bindkey "^?" backward-delete-char
# Change cursor shape for different vi modes.
function zle-keymap-select {
if [[ ${KEYMAP} == vicmd ]] ||
[[ $1 = 'block' ]]; then
echo -ne '\e[1 q'
elif [[ ${KEYMAP} == main ]] ||
[[ ${KEYMAP} == viins ]] ||
[[ ${KEYMAP} = '' ]] ||
[[ $1 = 'beam' ]]; then
echo -ne '\e[5 q'
fi
zle -N zle-keymap-select
zle-line-init() {
zle -K viins # initiate `vi insert` as keymap (can be removed if `bindkey -V` has been set elsewhere)
echo -ne "\e[5 q"
zle -N zle-line-init
echo -ne '\e[5 q' # Use beam shape cursor on startup.
preexec() { echo -ne '\e[5 q' ;} # Use beam shape cursor for each new prompt.
