How to disable monitor mode and return to managed mode?
After enabling the monitor mode using airmon-ng start wlp2s0 (as root), I’m unable to disable it and return back to managed mode.
I’ve tried the following (as root):
ifconfig wlp2s0mon down
iwconfig wlp2s0mon mode managed
ifconfig wlp2s0mon up
But when I checked using ifconfig , wlp2s0 was still showing up as wlp2s0mon , which means it was still in monitor mode.
(Finally, I had to reboot to turn monitor mode off)
Or you could have run airmon-ng stop wlp2s0 to stop it I guess.
You should try it next time, just to make sure. :slight_smile:
To disable monitor mode and go back to managed mode, I ran the following:
sudo airmon-ng stop wlp2s0mon
Note: Use mon after the name of the wireless network interface card (since it’s in monitoring mode), else it’ll not work.
