OBS Studio: Questions About CPU Usage and Nvidia Frame Buffer Capture (NVFBC)
I’ve recently installed OBS Studio for the first time and I was trying to figure out how much overhead it creates. Luckily, so I thought, OBS Studio actually displays its CPU utilisation on the bottom right of its window. A measly 1.8 % seemed fine to me—that was still more than what I saw in a recent LTT video, but different specs and all … Nonetheless, I decided to launch htop and filter for “obs.” For some reason, htop shows me a different value for OBS’ CPU usage than OBS itself does (see attached screenshot below).
As you can see, OBS Studio shows a CPU usage of 1.7 to 1.8 %, whereas htop shows me values of 22.1 % and 12.3 %. Am I misinterpreting the results in the terminal or is the display within OBS Studio somehow bugged?
A second question I have concerns the method of enabling Nvidia’s Frame Buffer Capture, NVFBC, as a source in OBS Studio that was shown in the video mentioned (and linked) above. They did it in Pop!_OS, but is this method applicable for Manjaro as well? I found an AUR package that supposedly adds NVFBC as a source to OBS Studio, but sadly I couldn’t find anything regarding this topic on the Arch wiki. Does anyone have experience with this and could share perhaps?
Edit:
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=628f24a1-5443-4159-99a5-4a1e4dfaa518 rw quiet apparmor=1
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 81HE v: Lenovo Legion Y740-15ICHg
  serial: <filter> Chassis: type: 10 v: Lenovo Legion Y740-15ICHg
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
  UEFI: LENOVO v: AVCN22WW(V1.12) date: 07/20/2020
  ID-1: BAT1 charge: 53.9 Wh (99.8%) condition: 54.0/57.0 Wh (94.7%)
  volts: 12.9 min: 11.5 model: SMP L17M3PG2 type: Li-ion serial: <filter>
  status: Unknown cycles: 17
  ID-2: hidpp_battery_0 charge: N/A condition: N/A volts: 3.8 min: N/A
  model: Logitech G903 Wired/Wireless Gaming Mouse type: N/A serial: <filter>
  status: Discharging
  RAM: total: 15.55 GiB used: 4.15 GiB (26.7%)
  Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: EA cache: L2: 9 MiB bogomips: 52815
  Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
  driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f51 class-ID: 0300
  Device-2: Chicony Integrated Camera (1280x720@30) type: USB driver: uvcvideo
  bus-ID: 1-7:6 chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
  s-diag: 583mm (23")
  Monitor-1: DP-4 res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
  class-ID: 0403
  Device-3: C-Media Q9-1 type: USB driver: hid-generic,snd-usb-audio,usbhid
  bus-ID: 1-5:4 chip-ID: 0d8c:0135 class-ID: 0300
  Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: yes
  Device-1: Intel Cannon Lake PCH CNVi WiFi
  vendor: Rivet Networks Killer Wireless-AC 1550i Wireless driver: iwlwifi
  v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 3f:00.0
  IF: enp63s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 1.38 TiB used: 837.98 GiB (59.5%)
  model: PC SN720 SDAPNTW-512G-1101 size: 476.94 GiB block-size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
  serial: <filter> rev: 10130001 temp: 44.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
  type: SSD serial: <filter> rev: 033 scheme: GPT
  ID-1: / raw-size: 204.8 GiB size: 200.59 GiB (97.94%)
  used: 163.35 GiB (81.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 628f24a1-5443-4159-99a5-4a1e4dfaa518
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 29 MiB (11.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM_DRV uuid: D48E-60B3
  ID-3: /mnt/8EC28FE8C28FD2BF raw-size: 475.69 GiB size: 475.69 GiB (100.00%)
  used: 189.62 GiB (39.9%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
  label: Windows-SSD uuid: 8EC28FE8C28FD2BF
  ID-4: /mnt/Data raw-size: 576.06 GiB size: 576.06 GiB (100.00%)
  used: 454.74 GiB (78.9%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Data
  uuid: 01D75132E5F5E0F0
  ID-5: /mnt/Data2 raw-size: 150.64 GiB size: 147.21 GiB (97.73%)
  used: 30.23 GiB (20.5%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Data 2
  uuid: 708fcbc1-116d-49bb-9171-a77b48962022
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
  uuid: D28E90838E9061B1
  ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c539 class-ID: 0300
  Device-2: 1-4:3 info: Integrated Express ITE Device(8910) type: Keyboard
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 048d:c936 class-ID: 0301
  Device-3: 1-5:4 info: C-Media Q9-1 type: Audio,HID
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0135 class-ID: 0300
  Device-4: 1-6:5
  info: Integrated Express Corsair Gaming K95 RGB PLATINUM Keyboard
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 048d:c935 class-ID: 0300
  Device-5: 1-7:6 info: Chicony Integrated Camera (1280x720@30) type: Video
  Device-6: 1-14:7 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 54 C
  Processes: 298 Uptime: 18m wakeups: 3 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1503 pacman: 1499 lib: 437 flatpak: 0
  snap: 4 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Please read this:
More specifically:
  1. Also please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. As you have an Intel Core i7 8th Gen that has 4 cores with 8 threads, 20% / 8 = 2.5% so are you sure that htop is showing the entire CPU or that OBS is showing just one core/thread?
:+1:
Sorry about that, I didn’t know how to copy and paste the results from htop, so taking a screenshot was the only thing I could think of.
I added the output of the inxi to the end of the opening post.
If I’m to believe my specs, I have a 6-core CPU, an Intel Core i7-8750H, with apparently 12 threads. Looking at the screenshot, it does appear as though htop displays all 12 threads. It’s possible that OBS Studio only shows one, but I wouldn’t know. Using the System Activity Monitor (Ctrl + Esc on KDE) also shows OBS with just 1 % CPU usage, which just further confuses me.
Did some more digging:
top measures the entire CPU and htop measures the individual cores (not threads) and both average them out differently.
Your system activity in OBS used the top philosophy, so in a nutshell:
Yes, it’s entirely normal for a single core to be running at a 20% peak wile your overall average CPU usage is just 2%
:+1:
I see, well that’s good to know, then. Thank you!
