How to create a shortcut for virtual desktops?
As I mentioned in the title, is there a shortcut or can I assign a shortcut so that I can easily switch between virtual desktops ?
By default there should be 4 shortcuts for 4 virtual desktops. Ctrl+F1-4. If you want more or assign other shortcuts go to System Settings ā†’ Shortcuts ā†’ KWin
Thanks for information :slight_smile:
Perfect, been looking for those myself as well. Iā€™m too used to the ctrl+alt+up/down shortcuts
