How do completely remove PulseAudio? When I installed PipeWire using sudo pacman -S manjaro-pipewire
, it prompts for conflicts between existing Pulesaudio packages and I entered Yes for everything. After reboot, inxi -Fazy
still shows PulseAudio as a Sound server but it’s not running. I also checked systemctl
, but no Pulseaudio-related services running.
inxi -Fazy
output:
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7699822a-f9ff-4a88-8441-057b8de4b1b4 rw apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Portable System: Dell product: Inspiron 5555 v: A12
serial: <superuser required> Chassis: type: 8 v: A12
Mobo: Dell model: 0CHHXW v: A00 serial: <superuser required> UEFI: Dell
v: A12 date: 08/30/2016
ID-1: BAT1 charge: 37.5 Wh (100.0%) condition: 37.5/41.4 Wh (90.5%)
volts: 16.5 min: 14.8 model: SIMPLO DELL VN3N047E47F type: Li-ion
serial: <filter> status: full
Info: model: AMD A10-8700P Radeon R6 10 Compute Cores 4C+6G bits: 64
type: MT MCP arch: Excavator level: v3 note: check built: 2015
process: GF 28nm family: 0x15 (21) model-id: 0x60 (96) stepping: 1
microcode: 0x6006110
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB
desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1436 high: 1494 min/max: 1300/1800 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1423 2: 1413
3: 1494 4: 1415 bogomips: 14377
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Dell driver: amdgpu
v: kernel arch: GCN-3 code: Volcanic Islands process: TSMC 28nm
built: 2014-19 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:01.0
chip-ID: 1002:9874 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 2-4:3 chip-ID: 0c45:6712 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0661 built: 2016
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon R6 Graphics (carrizo
LLVM 14.0.6 DRM 3.42 5.15.85-1-MANJARO) direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell Vostro 3470 driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 2-1:10
chip-ID: 0cf3:e005 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 1.03 TiB used: 981.07 GiB (93.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 8BS scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 116.77 GiB (98.17%)
used: 82.79 GiB (70.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 70.0 C mobo: 60.0 C sodimm: SODIMM C gpu: amdgpu
temp: 70.0 C
Processes: 239 Uptime: 43m wakeups: 1 Memory: 7.22 GiB used: 2.81 GiB (39.0%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1803
libs: 496 tools: pamac,yay Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.24
