A recent install. Just updated.
Old Dell Latitude e6410, details below. Very small touchpad.
After first install the touchpad didn’t work, it kind of moved a couple of pixels, unpredictably.
I tried installing xf86-input-synaptics but it is still jittery and 1 finger causes scrolling if two-finger scrolling is switched on.
The touchpad is about half the size of that found most new laptops these days, so I think the two finger detection is not right.
Earlier versions of manjaro worked fine with touchpad on this machine I think with synaptics. But I haven’t installed manjaro on it for a couple of years.
I tried reverting to 5.4 Kernel also.
Tried some fixes found on other threads but no luck so far.
From /var/log/Xorg.0.log:
[ 7.642] (II) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: device does not report finger width.
[ 7.642] (--) synaptics: AlpsPS/2 ALPS DualPoint TouchPad: invalid finger width range. defaulting to 0 - 15
6.633]
Kernel: 5.4.141-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3173fdc4-66fa-4165-bb2b-482e7749696e rw quiet apparmor=1
security=apparmor resume=UUID=08e05050-ab9e-4441-8082-abeabcac902d
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: Dell product: Latitude E6410 v: 0001 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0667CC v: A03 serial: <filter> BIOS: Dell v: A17
date: 05/12/2017
ID-1: BAT0 charge: 18.8 Wh (100.0%) condition: 18.8/93.2 Wh (20.2%)
volts: 12.5 min: 11.1 model: Sanyo DELL HVHC014 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0
model: Logitech MX Vertical Advanced Ergonomic Mouse serial: <filter>
charge: 10% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 3.71 GiB used: 1.54 GiB (41.5%)
Info: Dual Core model: Intel Core i5 M 460 bits: 64 type: MT MCP
arch: Nehalem family: 6 model-id: 25 (37) stepping: 5 microcode: 7 cache:
L2: 3 MiB bogomips: 20227
Speed: 1470 MHz min/max: 1199/2534 MHz boost: enabled Core speeds (MHz):
1: 1470 2: 1484 3: 1466 4: 1496
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pdcm pebs pge pni popcnt pse pse36 pti
rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics
vendor: Dell Latitude E6410 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.0x9.4")
s-diag: 449mm (17.7")
Monitor-1: eDP1 res: 1440x900 hz: 60 dpi: 122 size: 300x190mm (11.8x7.5")
diag: 355mm (14")
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.1.6
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Dell Latitude E6410 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Sound Server-1: ALSA v: k5.4.141-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel 82577LM Gigabit Network vendor: Dell Latitude E6410
driver: e1000e v: 3.2.6-k port: 7040 bus-ID: 00:19.0 chip-ID: 8086:10ea
class-ID: 0200
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel
port: 7000 bus-ID: 02:00.0 chip-ID: 8086:422c class-ID: 0280
Local Storage: total: 344.68 GiB used: 11.65 GiB (3.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9250410AS
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SDM1 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: MBR
ID-1: / raw-size: 103.64 GiB size: 101.46 GiB (97.89%)
used: 11.65 GiB (11.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 3173fdc4-66fa-4165-bb2b-482e7749696e
ID-1: swap-1 type: partition size: 8.15 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 08e05050-ab9e-4441-8082-abeabcac902d
ID-1: /dev/sda1 maj-min: 8:1 size: 232.88 GiB fs: ntfs label: Data
uuid: 035552D75B36B772
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.2:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 2-1.8:4 info: Broadcom BCM5880 Secure Applications Processor
type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a5c:5800 class-ID: 0b00 serial: <filter>
System Temperatures: cpu: 53.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 187 Uptime: 6m wakeups: 3 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1131 lib: 335 flatpak: 0
Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
