How to change pcmamfm colors in dual view (i3wm)
Installed Manjaro i3 edition. Everything seems just fine except few small annoyances. One of them is Pcmandfm’s color of inactive panel in dual view (screenshot attached). Where i can change this color?
It might be some sort of bug with pcmanfm and the Manjaro gtk theme - if you change the Folder View Mode to Detailed List it does not do that.
The only way around it I see is to change or edit the gtk theme itself and why it only does it in one view mode I am not sure.
yes, this works. Only for detailed view mode though. But still thats acceptable workaround, thank you )
