After some troubles getting Thunderbird to behave as I like, I want to try Evolution. It looks promising, but I can’t figure out how to change (or add) keyboard shortcuts. I want a keyboard shortcut for searching for messages.
which seemingly has zero effect. At least typing CTRL-6 does nothing. I chose that shortcut because the entire A-Z seems to be assigned to various other stuff. E. g. the intuitive CTRL-f forwards the highlighted message.
I am not sure on how to add a new keyboard shortcut but you can use Alt+C to jump to Search bar. Same goes for a lot of other functions also. Just press Alt plus the underlined character to access that.
Turns out I was wrong: editing the file DOES work. Its just that editing the line to look like
makes it so that after entering a search string I can execute the search using CTRL-6 as well as ENTER. I was hoping my custom shortcut would activate or focus the search field instead.
I failed finding a useful guide to what the names in the accels file mean, so for now changing shortcuts is a trial and error task.
