Hey MANjaros,
I’ve came back to my old home -Manjaro- after 2 years almost. It looks very stable actually than when I’d left to try others. My old days boi is better today; congrats to the team and the community. And why my old account removed on forum btw? Anyways let’s look at the issue.
Just annoying issue is there what I could not solve it yet what maybe hardware related though, dunno. The issue is pixelation on
When blur and translucent enabled that dotted pixelation appears.
As you can see on the second image there is no pixel problem on my screen but just blurred/translucent parts. Nothing to do used theme coz already tried other translucent themes ans same result occured.
inxi -Fxz
System: Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.5
Machine: Type: Laptop System: Acer product: Nitro AN515-44 v: V1.04 serial: <filter>
Mobo: RO model: Stonic_RNS v: V1.04 serial: <filter> UEFI: Insyde v: 1.04 date: 02/04/2021
Battery: ID-1: BAT1 charge: 44.8 Wh (79.4%) condition: 56.4/58.8 Wh (95.9%) volts: 16.3 min: 15.4
model: SMP AP18E7M status: Unknown
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 rev: 1
cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92660
Speed: 2065 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 2065 2: 2731 3: 1397
4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1981 10: 1397 11: 1397 12: 1397 13: 1445 14: 1397
15: 1397 16: 1400
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Acer Incorporated ALI driver: nvidia
v: 470.63.01 bus-ID: 01:00.0
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Acer Incorporated ALI driver: amdgpu
v: kernel bus-ID: 05:00.0
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-3:3
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
resolution: 1920x1080
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.2.3
direct render: Yes
Audio: Device-1: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Acer Incorporated ALI driver: N/A bus-ID: 05:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 34 GiB (7.1%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN530 SDBPNPZ-512G-1014 size: 476.94 GiB
temp: 29.9 C
Partition: ID-1: / size: 151.53 GiB used: 33.95 GiB (22.4%) fs: ext4 dev: /dev/nvme0n1p4
ID-2: /boot/efi size: 1020 MiB used: 43.4 MiB (4.3%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 49.4 C mobo: N/A gpu: amdgpu temp: 32.0 C
Info: Processes: 380 Uptime: 55m Memory: 15.01 GiB used: 3.62 GiB (24.1%) Init: systemd Compilers:
gcc: N/A Packages: 1273 Shell: Zsh v: 5.8 inxi: 3.3.08
hwinfo --gfxcard
15: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.o+PC+8Gpi0C
Parent ID: mnDB.oGVH8zZKnmD
SysFS ID: /devices/pci0000:00/0000:00:01.1/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "nVidia TU117M [GeForce GTX 1650 Ti Mobile]"
Vendor: pci 0x10de "nVidia Corporation"
Device: pci 0x1f95 "TU117M [GeForce GTX 1650 Ti Mobile]"
SubVendor: pci 0x1025 "Acer Incorporated [ALI]"
SubDevice: pci 0x1447
Revision: 0xa1
Driver: "nvidia"
Driver Modules: "nvidia"
Memory Range: 0xd0000000-0xd0ffffff (rw,non-prefetchable)
Memory Range: 0xfcc0000000-0xfccfffffff (ro,non-prefetchable)
Memory Range: 0xfcd0000000-0xfcd1ffffff (ro,non-prefetchable)
I/O Ports: 0x3000-0x307f (rw)
Memory Range: 0xd1080000-0xd10fffff (ro,non-prefetchable,disabled)
IRQ: 98 (7120 events)
Module Alias: "pci:v000010DEd00001F95sv00001025sd00001447bc03sc00i00"
Driver Info #0:
Driver Status: nouveau is not active
Driver Activation Cmd: "modprobe nouveau"
Driver Info #1:
Driver Status: nvidia_drm is active
Driver Activation Cmd: "modprobe nvidia_drm"
Driver Info #2:
Driver Status: nvidia is active
Driver Activation Cmd: "modprobe nvidia"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #27 (PCI bridge)
28: PCI 500.0: 0300 VGA compatible controller (VGA)
Unique ID: Ddhb.vBXJnaVSGnA
Parent ID: JZZT.e+TNXSUNut3
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:05:00.0
SysFS BusID: 0000:05:00.0
Model: "ATI Renoir"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x1636 "Renoir"
SubDevice: pci 0x1455
Revision: 0xc6
Driver: "amdgpu"
Driver Modules: "amdgpu"
Memory Range: 0xfce0000000-0xfcefffffff (ro,non-prefetchable)
Memory Range: 0xfcf0000000-0xfcf01fffff (ro,non-prefetchable)
I/O Ports: 0x1000-0x10ff (rw)
Memory Range: 0xd1500000-0xd157ffff (rw,non-prefetchable)
IRQ: 63 (no events)
Module Alias: "pci:v00001002d00001636sv00001025sd00001455bc03sc00i00"
Driver Info #0:
Driver Status: amdgpu is active
Driver Activation Cmd: "modprobe amdgpu"
Attached to: #21 (PCI bridge)
Primary display adapter: #15
mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2021.07.28 false PCI
I’d installed Manjaro KDE with .iso and used Open Source drivers first. After figure out that annoying pixelated parts tried proprietary drivers but nothing changed.
How can I solve those ugly dotted pixels?
